1983 944 steering wheel
steering wheel is cracked and need to remove. what are steps to remove. making sure I don't break something, clips,etc. no airbag involved
Old 12-02-2014, 10:50 AM
Bradical's Avatar
It's really simple, the horn pad pulls off exposing a large nut (21mm? Citation needed...). As per usual Clark's Garage has a write-up on it. It's a good idea to use marking paint on the shaft so you have an idea on how to center it up when you go to reinstall.
Old 12-02-2014, 11:56 AM
Patrick
pfarah's Avatar
Actually, it's 24mm...
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 12-02-2014, 02:17 PM
Pretty sure mine was 21mm also.
Old 12-02-2014, 04:33 PM
ernie9944's Avatar
Link to Clark's Garage Home Page then enter ( Garage Shop Manual) & look for (steering wheel removal & installation,have fun.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 12-02-2014, 05:34 PM
Have 944, will restore
mazdaverx7's Avatar
-Remove the horn pad buy pulling it straight off. Three clips hold it on.
-Unclip the wire for the horn on the back of the pad
-Remove the but that holds the steering wheel in place
-Use a paint marker and draw a line over the steering shaft and wheel to mark the position of the steering wheel
-Wiggle the wheel top to bottom and pull towards you. The wheel should slide right off.
85.2 944 Guards Red M456 5spd
85 RX-7 Ocean Blue 5spd /80 RX-7 LS 5spd
84 RX-7 GSL-SE/ 88 RX-7 10th Anniversary
04 RX-8 Brilliant Black 6spd/ 04 RX-8 Nordic Green 6spd
84 Corvette 4+3, 93, 95 Corvette 6spd, 18 Camry SE
Old 12-02-2014, 06:34 PM
