Overheating Problem
I was driving my car a few days ago and I saw that the temp was going up very fast. It was a very cold day, that's why it surprised me. When I drove, the temp dropped fast, and when I stopped it went up really fast. Oh, and I also hear a whining noise coming from the front of the engine. Could it be the water pump? Maybe there's something wrong with the Thermostat? Water pump relay? Any suggestions? Thanks.
Ps. there is a significant amount of air bubbles in the expansion tank. I don't think it's a blown Hg because I don't smell a sweet exhaust, nor am I losing any coolant. If I turned off the car, it would flood with coolant and not start. It started up right away yesterday. I need help here! Thanks again.
88 951 with limited slip, k26/6 turbo, Guru Racing Chips, 3 Bar FPR, K&N, MBC set at 17 psi, Autometer Boost/AF gauges
Old 10-17-2002, 07:52 AM
I'd get it to the shop quickly if you are not inclined to look at it yourself. The squealing could be the water pump or some idler pulley. The cam belt drives the water pump. You know what happens if the cam belt breaks.
Bubbles in the water reservoir could mean a blown head gasket. If it filled the cylinders with water, it definitely means a blown headgasket.
You need to get it fixed and quit driving it or you'll be in for an even bigger repair bill.
Old 10-17-2002, 08:04 AM
The temp gauge going up and then down is a sign of lack of coolant = STOP DRIVING IMMEDIATELY.
There is a good possibility that the water pump is leaking and there is no coolant in the engine. This means the fuel injection sensor is not surrounded by coolant and will not register any temperature and therefore will "think" the engine is cold. The computer will then run the engine in cold start mode (rich).
Basically, you need to do a leakdown and compression test of the engine and a cooling system pressure test. If the head gsket hasn't failed right now, it will soon.
Any 944 that has overheated will need; thermostat and coolant sensor for DME. Turbos need the thermostat for the turbo coolant supply. You should also replace the oil cooler/tube seals.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 10-17-2002, 08:07 AM
Unhappy
I'm going to do it myself. i just want to make sure what the problem is. I 'm not going to drive the car at all. The thing is, I checked the coolant level, it's full. That's why I don't think it's a blown headgasket. I will definitely check the belt. It started right after this mysterious whining sound started. How big of a job do you guys think this is? Thanks for the replies. Any further info is greatly appreciated.
Old 10-17-2002, 08:30 AM
"If I turned off the car, it would flood with coolant and not start. "
What does the above mean? Where does it flood with coolant?
Old 10-17-2002, 08:49 AM
To get the water pump off you have to get the rear cover off from the timing belt housing because pump is behind it. You'll need a flywheel lock and a cheater bar to get nut off crank pulley. Replace the timing and balance shaft belts while your in there. If you have leaking balance shaft seals, you could do them too. I've never done those seals but they differ so put the correct one where it is supposed to go. They differ by 1mm so you can't see it. Pump is not hard to do. Did mine. I used a rebuilt water pump and it has worked out well.
Old 10-17-2002, 08:58 AM
Send a message via Yahoo to Cebu
My initial inclination is a stuck Thermostat, thus no coolant flow through the radiator. This is also indicated by blowback through the coolant reservoir due to enginge heatsoak after engine shutdown.
Old 10-17-2002, 12:49 PM
lawence, I was just saying if that were the situaton. If the situation was that I blew the HG, then when I would turn the car off, it would flood the cylinder wouldn't it? If that's the case, then It wouldn't start. My car started up right away. I hope it's not the HG. I think it's something minor, maybe the thermostat or the water pump. I'll let you guys know. Thanks for the replies.
Old 10-17-2002, 01:04 PM
951carter's Avatar
Have you checked to make sure your fans are coming on?
84 944(sold)
85 944
86 951
87 944(sold)
87 951
88 951
Turn up the BOOST!!!
Old 10-17-2002, 01:55 PM
that's when I started to notice something. the fans were coming on every minute or so. It was a cold day.
Old 10-17-2002, 02:56 PM
Ahhhhhhhhh, Sooooooooooooo...I no understanda da ingles too good.
Old 10-18-2002, 02:29 AM
i'm going to use process of elimination. I'm going to try and flush out the coolant system. How can flush it so every drop is out? Any suggestions? Thanks.
Old 10-19-2002, 07:22 AM
ae1969's Avatar
Send a message via ICQ to ae1969
Silver...... the thing that alarms me the most is the whirring sound..... If it is a thermostat/waterpump combo it would cause all the symptoms that you explain. (also the broken belt scenario as Britwrench explained!)... so identify the whirring a.s.a.p.
As you know the longer you run in an overheated situation the more you compromise your headgasket and eventually it will fail, assuming it hasn't already?
Britwrench: so you have too replace the coolant sensor after an overheated situation....uhmmmm makes sense, I love this board you learn something new everyday! I will file that info.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 10-19-2002, 07:54 AM
