Oil level dropping
No obvious drips or leaks.
Some minor discoloration around Oil/Water unit. Not all that wet. Minor oil weeping one screw on sump gasket, front, power steering pump side. No blue smoke. Don't think I'm burning it. No black stain on the drive. Oil looks clean (but I'm topping it up regularly.. hmmph!) Coolant looks cool; ie blue and no oil, no foam. Oil Air separator no brown gunk or condensation. What have I missed? Apart from about 1/4 pint of oil every 150 miles. Any ideas, Rissole
944 Alpine White '89 2.7L |
Toofah King Bad
Therapy? That's a quart every 1200 miles, you're likely burning it. Not ideal, but not the end of the world either.
Just drive and enjoy.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
That Guy
Take the intake boot off and look at the throttle body for any oil pooling. Might be getting sucked through the intake due to a vacuum leak somewhere in the air oil separator hoses.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
Porsche's "OK" oil-consumption spec is 1L/1000km = 1QT/620 miles so you're doing pretty good if you drive the car regularly and go hard from time to time.
