930s rule the wasteland
part#s , allen bolts,left front of head
cant find these #s in the fische for the life of me, any one know them? they are the 2 different length allens below the water neck that secure corner of head to block.
1980 930 Turbo 1993 Corrado 1983 944 1984 944 2001 VW golf TDI |
I also needed those two bolts and could not find the part numbers, I contact Ian at 944online and he was able to provide based on the description.
1981 924 Turbo 1987 N/A Auto Black w/Can-Can Red Interior |
Picture? I am guessing you are looking at a 924?
Semi-helpful link Porsche Original Parts Catalogue - Parts and Diagnostic Information - Porsche Service - Dr. Ing. h.c. F. Porsche AG Maybe these bolts? No part numbers but the lengths are listed. Size Of Two Front Bolts on Cylinder head Last edited by Shifter; 01-21-2015 at 03:28 PM.. Reason: adding link |
Look further down in the PET to the page with the aux air mounting bracket to see if that is what you are looking for.
No dice, I found the water outlet bolt numbers , they are NLA. The aux air regulator bolts are both the same length. I will try to get pictures. it doesnt matter if it is a early motor or late the both have these bolts.
In the Fires of Hell.....
Shifter gave you your answer on Page 2 of the second link...
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
Ok, I have demensions, I can deal with that. Thanks for the help!
