Kerrpapa's Avatar
Smile Power Steering Bracket replacement
Hey, new 944 owner. My 87' 944' that I just bought has a bent power steering pump bracket. The previous owner bent it loading onto a trailer. The pulley is just a bit tilted outwards. Has anyone ever changed out one of these brackets? If so, is it a hard job? Thanks!
"Live life in Moderation, Toleration, and daily Self Examination"
Old 06-24-2011, 07:47 PM
The power steering pump attaches to a cast aluminum piece that also serves as the lower balance shaft cover. Replacement is not terribly complicated. If the car is not needed as a daily driver, you might just cut off the p/s bracket portion of the cover and swap it with someone who runs a manual rack on a '84+ car.might be able to get your replacement bracket for free. See clarks garage for balance shaft seal replacement proceedures
Old 06-24-2011, 10:38 PM
Over 40 victim of fate
stogie25's Avatar
Mine broke a few weeks ago. I will be replacing it in two weekends when I have help. It is next to the water pump, which means the timing belt, balance belt, pulleys, and timing belt rear cover have to come off to get to it. At that point a new water pump seems logical.
black 1988 Porsche 944 (30 years old and getting younger every day)
black 1997 Jeep Wrangler (very modified)
I didn't know cars came in other colors
Semper Fi
Old 06-25-2011, 04:20 AM
vdubr928's Avatar
Nope. No need to pull the belt. I have a spare if either of you want one. 20$+ shipping sound reasonable? One of you I saw is in denver. If you swing by the house ill show you a disassembled block and show you how it comes off.
82 928 s3&1/2 5 Speed LSD conversion
87 944 N/A 5 Speed (Under Construction)
81 931 (maybe for sale, well their all for sale lol)
Always looking for a good deal. Hello, my name is Carl and im a Poschaholic
Old 06-25-2011, 07:08 AM
Diving in 911
Anyone ever end up doing this? Im about to replace a motor and need to take the good one off the motor coming out and put it on the motor going in. Having a tough time finding information on this one. vdubr928, I would love to avoid disturbing anything I don't need to. What is your take?
1976 911s Special Edition Turbo bodied IROC tribute
2002 911 Carrera C4S
1971 914 1.7 Tangerine
1989 964 Coupe/1992 964 Cab
1987 928s4 Granite Green / 1986 951
Old 01-21-2015, 07:01 AM
Bradical's Avatar
The bracket is a aluminum cast piece as mentioned before and bolts onto the face of the motor, and also acts as the lower balance shaft sealing face. You would have to pull the balance belt and lower balance shaft pulley and the rest is bolt-on- it doesn't have a gasket or anything like that other than the balance shaft seal itself (you don't need loctite 574 or anything like that). Very simple.
Old 01-21-2015, 07:06 AM
Diving in 911
Thanks Bradical! Just mark the position of the shaft? Will it free-turn with the belt off?
Thank Again!
Old 01-21-2015, 08:19 AM
Bradical's Avatar
Yeah, it will free turn, it will actually wobble a bit without the seal because it's only supported by a single bearing 8-10 inches back or so and the front seal.
As far as marking the shaft, the balance shaft pulleys have two slots for a woodruff key because the upper and lower are the same pulley but the shafts are designed to be 180deg out from each other. There is a notch on the pulley and a notch on the rear timing cover to line up. Read Clarke's on how to do the balance belt and you'll know it all!
Old 01-21-2015, 02:00 PM
Diving in 911
Ah ha!
Thanks for the insight!
Old 01-21-2015, 04:42 PM
Bradical's Avatar
Thats the whole reason we come here!
Old 01-22-2015, 02:46 AM
