DME Relay and spark
Does the DME Relay have anything to do with spark or ignition or is it just strictly a relay for the fuel pump?
I have a 1985.5 944 and am having some ignition/spark problems.
I have read a lot about the DME relay and how they go bad and cause starting issues and was getting ready to order a new one and on the description for the part it describes it as the "Fuel Pump Relay". Is there another DME relay that controls spark?
I have plenty of fuel but sometimes the car will start fine, other times there is no spark and it obviously won't start. When it does start, I can be driving down the road and then it just shuts down immediatley like I turned the ignition off. I replaced the 2 reference sensors on the bell housing a couple weeks ago. Thanks.
Old 01-28-2015, 03:29 PM
930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
could be ignition switch as well.
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 01-28-2015, 05:17 PM
nightheart's Avatar
clarks has a write up on testing the DME and symptoms of failure.
DME Relay Information and Testing
The relay also provides power to the DME, so it could be causing your problems. I'm kinda doubtful, but the relays are cheap enough and you should have a spare in your glovebox anyway, so you might as well order one. I'd check your wires and grounds too. Mine did something like that because some idiot (me) didn't have the negative battery terminal tight enough. It was tight, but just not tight enough. These cars are really sensitive to ground/electrical issues. That fix is cheap and easy, before you tear into something more expensive and time consuming.
This was probably posted from my phone, so please excuse any typos.
Old 01-28-2015, 06:06 PM
Does the car have a factory alarm system?
Old 01-28-2015, 08:15 PM
yes, it does have a factory alarm.
Old 01-29-2015, 06:29 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Loose alarm connections, defective ign switch or it's loose connector, loose connections on coil, and always carry a couple of DME relays. They're cheap and when one goes Pfffft, you won't be stranded.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 01-29-2015, 06:33 AM
The alarm can de-power the DME (via the DMA Relay) and shut down the car. There is a simple procedure to bypass the alarm: Search Clarks Garage for "alarm". There are a number of ways that the alarm system can intermittently fail and cause problems. I once had a pin-hole sized perforation in the battery compartment on my 951 leak down onto the alarm controller (it's under the passenger footwell with the DME and KLR) and cause start/run problems. I replaced the controller with a salvaged one but now carry a couple of leads to bypass it with me these days.
This may well not be what is happening to yours, but it is an easy one to test.
Old 01-29-2015, 11:22 AM
