Mountain Road Maniac
Heater hose replacement
Found out what happened to cause my '83 na to overheat and leak coolant all over the floor: busted heater hose going into the firewall. The leak is in the middle of the hose and it seems easy enough to disconnect at the top, but I can't see how it's connected at the firewall. I can't find this procedure described at Clark's and nothing in the Hayne's manual either. Help!
Steve '83 944 '87 951- SOLD! |
its connected to the heater core behind the dash. Not fun at all. Not really advised, but if your sure you have can get all the break in the hose out, you can cut it and splice in another piece of hose using connectors and hose clamps.
1983 944 This was probably posted from my phone, so please excuse any typos. |
That's what I was afraid of...I'll try to cut and splice 'cause I've got to move the car and don't have time to do a proper repair. You'd think those crazy Germans would make it possible to replace a simple hose without tearing the car apart!!!
Found the problem
Turns out it wasn't the heater hose...yeahhh...it was the heater control valve, a plastic part that melted and got a hole in it somehow and that's where the coolant was leaking out.
i waited until my engine was out of the car to do the heater hoses...if thats an indication.
930s rule the wasteland
Ditch the Haynes manual too, pretty worthless in my opinion.
1980 930 Turbo 1993 Corrado 1983 944 1984 944 2001 VW golf TDI |
