944 boot won't open....help
HI
Just picked up my 1986 944 non-turbo and can't open the bloody boot (that's trunk to you americans).
Key goes in. It turns 90 degrees to the left in the lock itself but what should i be doing?
Please help if you can
MJ in Beirut
Old 01-29-2015, 02:44 AM
TIG Welder
doublestuff's Avatar
The pins in my hatch are misaligned, so when I try to open it, I have to turn the key and then push the hatch forward and side-to-side until it finds its "sweet spot" and opens. I don't know if this is a common problem, but it might be worth a try. The bushings where the hatch pins seat commonly wear and could be binding. Good luck and let us know what it is when you figure it out!
'79 SC Targa (SOLD)
'85 944 (SOLD)
'86 951 (SOLD)
'97 Boxster (SOLD)
Old 01-29-2015, 03:17 AM
when you turn the key, which WAY do you turn it. And then, do you push the entire knob in as well for the 'pop'?
thanks again
Old 01-29-2015, 03:43 AM
Proprietoristicly Refined
John_AZ's Avatar
When you get the rear hatch open, check the hatch pin receiver rubber pin seats. if they look rotted and worn-replace.
I bought a set from Only944 and they work great.
Hatch Pin Seats - Only944.com Awesome new Porsche 944 parts
The hatch pin receivers can be adjusted by loosening the 2 nuts and turning slightly.
Crawl into the rear and loosen with a 10mm wrench while you gently push up with your shoulder and the hatch should open while you grab
the linkage to open the receiver "claws"
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 01-29-2015, 04:03 AM
Also you might check at this time whether the automatic hatch release works. It is the button down in front of the hood release in the drivers side footwell.
Old 01-29-2015, 04:15 AM
