Diving in 911
951 wastegate issue...
Short of it is the old motor has a single port vacuum line on the wastegate. New motor does not have a port for it on the SEM vacuum router, I assume it was a 2 port wastegate on the donor car. Any issue in switching out the SEM to the one with the correct number of ports?
1976 911s Special Edition Turbo bodied IROC tribute
2002 911 Carrera C4S
1971 914 1.7 Tangerine
1989 964 Coupe/1992 964 Cab
1987 928s4 Granite Green / 1986 951
Old 02-03-2015, 01:31 PM
Diving in 911
Nobody with an idea on this?
Old 02-04-2015, 09:27 AM
Toofah King Bad
Rasta Monsta's Avatar
I'm afraid I don't know what a single port vacuum line is, or an SEM router.
I'd throw out an idea if I could. . .
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 02-05-2015, 07:22 AM
Diving in 911
Thanks Rasta, it's the Cyclic Valve and "single port" would be the number of vacuum connections on the wastegate. Some have 2 and some, like mine, have 1 vacuum port for a hose connection. One the old motor the CV has a dedicated port to run to that connection on the wastegate. The new motors CV does not have that port. So I'm trying to figure out if I can tie my old wastegate in somehow and where to do so.
Old 02-05-2015, 08:58 AM
In the Fires of Hell.....
kdjones2000's Avatar
Sounds to me like your cycling valve has a nipple broken off - it is very common.
All models have 3 nipples on the cycling valve. I know of no exceptions to this.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 02-05-2015, 05:56 PM
