What is this red button for?
I noticed my clutch was too close the brake pedal. I pushed it in and over to the left and it is now firm in place. no more side to side play. but now the red button isnt being compressed. whats it for? should i be worried? Car is DD.
Silver '83 944 - RIP 12/12/2014
Old 03-10-2015, 11:35 PM
Toofah King Bad
Rasta Monsta's Avatar
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 03-11-2015, 12:02 AM
It lets the cruise control know when the clutch has been depressed so it will shut off and not over revv the engine. Vehicles without factory cruise don't have it.
1986 944 -Garnett w/Koni suspension
1987 924S -Red, 951 Swapped, ~300hp
1987 924S -Red, project car
1987 924S -White, Project car
1988 924S- Red, Bone stock, Daily driver
Old 03-11-2015, 12:25 AM
Funny because cruise control doesn't work anyway. Ha!
Old 03-11-2015, 06:27 AM
Straight shooter
Lapkritis's Avatar
You might want to check the cruise control now that the button is depressed... if everything else is intact. The bottom un-pressed would cause the cruise to turn off, simulating the clutch being pressed.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 03-11-2015, 07:22 AM
In the Fires of Hell.....
kdjones2000's Avatar
Dude, your clutch pedal is FUBAR.
It should be landing on that black rubber pad at the top of your picture, not off to the side like it is.
You are so far off that the metal tab is not touching the CC interlock switch, like others mentioned above.
Take a good look at what's going on, or something big is going to happen I fear.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 03-11-2015, 10:07 AM
PorscheChef's Avatar
Flux Capacitor cut off switch?
'87 951 Nile Green, '86 951 Black, '86 951 Sapphire Metallic, '87 944 Nautit Blue, '84 944 Black (sunroof delete) "Track Beast!," '87 944 Black (LSD, Konis) (wife's track car)
Old 03-11-2015, 07:33 PM
Ornery Bastard
That your clutch pedal is either horribly bent or that it's pivot is loose enough for it to flex that much?
Yes, that should be a worry.
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 03-11-2015, 09:23 PM
Could the plate on which the button is mounted be bent, rather than the pedal? Realign the plate and problem solved?
Old 03-12-2015, 08:33 AM
Toofah King Bad
+1 on that pedal cluster. Yikes.
Old 03-12-2015, 08:46 AM
911tracker85's Avatar
also, I have read references to the firewall sometimes cracking around the clutch master and flexing.
Bob Cox
78 930 clone project car.
87 924S resurrect at some point.
84 928S, Ruby Red linen/brown interior - sold
86 944 turbo my new DE/track car - sold
Old 03-12-2015, 03:02 PM
