new here- question about motor mounts
I have a 84 na. Motor mounts need to be replaced. I have read all I can find on the procedure, and ready to do it. Just one question, ome or aftermarket and why??????
86 944 daughters
88 944 step-sons
07 Ranger 4x4
I have tons of spare parts, let me know what you need.
Old 10-30-2002, 08:31 PM
SoCal Driver's Avatar
Many report the after market mounts lasting less than two years.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-30-2002, 09:56 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
I have an '84 also. I would go with OME, they reportedly changed the design a tad since ours were first put on. (yes, I changed mine, too)
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 10-30-2002, 09:57 PM
AFJuvat's Avatar
I concur. I have not seen the aftermarket ones last.
It is an ugly job to replace them - you will want to avoid having to do it again any time soon.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 10-31-2002, 02:57 AM
Sternn's Avatar
What about after market solid motor mounts? They claim to be superior, and since they are solid and not rubber, would they not be better? The only question I would have is do they help eliminate the 'engine shudder' feeling you get in the cab when your mounts begin to go.
http://www.lindseyracing.com/944eng3.htm
- Sternn
- 944S - Project Car
- Web Master & Used Part Guru From
- www.stuttgartparthaus.com
Old 10-31-2002, 05:38 AM
Goku's Avatar
Solid motor mounts are for 'racing'. They won't give you a smooth ride. They are for track use. If this is a daily driver I wouldn't recommend solid mounts
ßrªÐL£µ
88' 951 - Wolf's now :'(
Reluctantly crouched at the starting line...
Old 10-31-2002, 08:35 AM
Sternn's Avatar
Thats what I was thinking, but those purple steel mounts look so cool under the hood!
When my other mounts started to go bad, the whole cab shook like one of those vibrating beds when you reved the engine. I'm guessing the rubber mounts damper that, and the solid mounts would transfer that same vibration right back into my seats again.
But still, purple steel is cool.
-S
- Sternn
Old 10-31-2002, 08:44 AM
