LinkBack | Thread Tools | Rate Thread |
More Boost!
Thanks much, I'll hopefully do it tonight and get the car on the road this week.
![]() Here are the belts side-by-side on a sprocket. This should help people better understand the difference, I do a lot of belt changes the two belts install the exact same way.
1986 944 -Garnett w/Koni suspension 1987 924S -Red, 951 Swapped, ~300hp 1987 924S -Red, project car 1987 924S -White, Project car 1988 924S- Red, Bone stock, Daily driver |
winter-hater club member
very nice. and i had major problems with the one on the left. i've never had a problem with the one on the right.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
More Boost!
The only issue is the supercharged belt whine now, I need to do some fine adjustments to the idler roller and the tension to make that whine disappear. I bit the bullet and bought the offset wrench to adjust the roller/tensioner for $19.50, doing it with my adjustable wrench has been driving me crazy. Almost there! |
Toofah King Bad
Whine will never disappear. If the belts are silent, they are not tensioned correctly.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
I have done 3 belt changes and numerous retensions and I have never been able to eliminate the whine completely. I have played with that idler roller and the tensioner with all the patience of my advanced years. Learn to love the whine.....
Jon
87 924S 82 924-Gone. 80 924 parts car-Gone. |
More Boost!
![]() A supercharged 944 Turbo. Maybe a 1st in existence? |
More Boost!
The offset wrench should be in by Thursday-Friday, just in time for the weekend.
More Boost!
Received the offset wrench on Thursday and finally got to the car this afternoon. Truth be told, the offset wrench in my case, made the balance belt and idler roller adjustments/torquing 100% easier.
Best $19.50 I have spent on the car. I digress. So after I adjusted the tensioner and the idler roller, I started the car and the whine was still there, but after about 3-5 minutes the whine was very subtle, nothing like it was before. I proceeded to re-install the belt covers with some new stainless steel bolts and washers, installed and tensioned new alt and p/s belts, put the afm back in place, double checked my work, cleaned up and wiped down my tools and put them away. Car is ready to roll again after a long New England winter, finally! |
Toofah King Bad
Good job
More Boost!
Thanks Rasta, gave the car a bath and snapped a quick pic.
