1985.5 Porsche 944 n/a to turbo
I know this has been talked about plenty of times that's its a dumb idea and cost effective but I just want to have a project for this car something that will really improve performance besides handling. Money isn't a problem but I would really appreciate help to find the parts that would make the car run efficiently and to turbo charge the engine I'm taking my car apart rebuilding the engine and making everything ready including space for the intercooler ..would appreciate if some one could recommend one but anyways what are good brands and parts for installing the turbo types of pistons the compression rings valves everything just name it I've been doing a lot of research on this and I know it's possible just I Want mine running the best it can possibly even beating turbo s specs
Proprietoristicly Refined
First, a rather frequent topic:
Turbo a NA 944.. If "money" is no problem, just search the cars for sale sections of the forums, craiglist, AutoTrader +++ and buy the beast of your choice for a lot less money and time you would spend doing it yourself. J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
The newest of the noobs!
There is a turbo motor for sale in the parts for sale section. Cheaper option, or, buy a turbo car as mentioned!
1989 944 Turbo 2004 Jeep Wrangler Unlimited - Built! 1985 Saurer 6dm overland Swiss military truck/camper |
If you have a naturally aspirated car and want forced induction, this is how I see the options (in order of sanity):
1.) Sell NA car, but 951. 2.) Supercharge the 944. 3.) Turbocharge the 944.
-Brad 2002 Carrera2 1986 944 Turbo |
Andrew Gawers' Dad
Also, define "money isn't a problem," please. Because if you spend any amount of time browsing 951 builds, you will find guys who spend enough money building their 3.0+ liter DOHC big turbo engines to BUY a 996.
If "money isn't a problem" I would look at a turbo 911 and have something I wouldn't have to bloody my knuckles on, or step over and around mid project.
I have a turbo going up for sale...I'll tell you what, trade me yours, give me a stack of cash, I'll kick you in the nads, then we will call it a day!
'87 951 Nile Green, '86 951 Black, '86 951 Sapphire Metallic, '87 944 Nautit Blue, '84 944 Black (sunroof delete) "Track Beast!," '87 944 Black (LSD, Konis) (wife's track car) |
Toofah King Bad
+1
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
See the thing is I can buy another car with no problem but I grew up with this car and I've had it for a few years it was my first car and I don't want really high numbers just I wanna be able at least beat a stock mustang I raced a 2006 gt 4.7 and lost by a car length so there's the hope of winning you know and I was already gonna rebuild the engine just when I have everything out I wanna be able to just put all the turbo parts on while its out get around 260hp not to much like the 951 just where it feels faster and goes faster I just wanna make this a huge project that can last awhile
Toofah King Bad
Easiest path to a turbo conversion, IMO, is to buy a running 951 (like THIS ONE) and park them next to each other in the garage until you are done.
Requires many mods!
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc Last edited by Rasta Monsta; 04-23-2015 at 08:52 AM.. |
In the Fires of Hell.....
And please, buy some punctuation in your posts...
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
See what I want is not critiscim I want help for this project I don't want people recommending new cars and such I wanna keep this one and have a project that I will feel proud for doing
Well then in that case, buy a wrecked/burnt 951 and swap EVERYTHING into your 944.
What I was hoping to get from the forum was help with the parts that I'm gonna install like piston brands what kind of turbo intercooler size does the front bumper have to be replaced all the little details to help me make this project successful
Most people that turbo an n/a from scratch (i.e, using no 944 turbo parts) fail.
There are more completed turbo conversions around because they have used 944 turbo components, and/or a 944 turbo parts car. You're better off finding a 944 turbo engine with all the plumbing and rebuilding it. You still get your project that way though how you get there will change. Can it be done piecemeal? Yes. but there are far fewer people who can help you if you go this route.
https://www.instagram.com/kiwi944s3/ '86 944S3 conversion - '94 968 3.0 engine - 6 spd/LSD - 17x8,17x9 Oz Racing Crono wheels |
(1) 951 crank (1) 951 oil pump (1) 951 oil cooler (1) 951 oil pressure relieve valve (4) 951 pistons (4) 951 rods (1) 951 short block rebuilding kit This will get you started |
How about an LS swap?
10 E92 M3 13 Jeep GC Limited 98 Jeep Cherokee 87 951 C3 Stingray |
(4) 951 brembo brakes, rotors (1) 951 trans (Many) 951 heat shields (1) 951 cylinder head (1) 951 intake manifold (1) 951 exhaust system and crossover (1) 951 bov (1) 951 intercooler (4) 951 struts (1) Aftermarket boost gauge (1) 951 engine harness, DME, KLR (1) 951 clutch and flywheel
Mike A 9TECHNIK | TRANSAXLE ÄRA 1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab. |
