JBC JBC is offline
JBC's Avatar
1985 944 Engine
What are the issues/problems of taking an engine from a 1985 944 automatic and putting it into a car with a manual transmission? Thanks. JBC
Old 06-06-2015, 05:29 AM
you have to swap the clutch parts onto the auto engine of course
you need to install a pilot bearing.
you need to remove the auto trans fluid lines along the side of the engine.
otherwise the engines and DME are the same.
Old 06-06-2015, 06:38 AM
JBC JBC is offline
JBC's Avatar
Rocket, thanks. I have a great running 1983 944 manual and I'm looking for a donor car for parts. I found an 85.5/1 automatic in a junk yard that is the same color, interior, etc. So, I'm trying to determine how much of the junker is usable as a loaner. Sounds like a lot.
By the way, do you, or anyone reading this one, know if the 85.5/1 have forged rods and crank like the 83?
Thanks,
JBC
Old 06-06-2015, 10:22 AM
All 944 cranks are forged. Rods are cast from 84 on in all non turbo models. Even the 89 turbo S got cast rods though so they're OK for strength.
Old 06-07-2015, 04:28 PM
