ASE Master
alfadoc's Avatar
Block Drain P/N?
I need to order a new block drain plug and sealing washer. My young assistant seems to have misplaced the one on our 84 resurrection project. Can't for the life of me find it in the PET. Can anyone assist?
Many thanks!!!
Old 06-09-2015, 05:14 AM
944 107 197 01 and 900 123 118 30 from illustration 101-15 in the S2 pet? (101-10 in the 84 model...same numbers)
Old 06-09-2015, 05:52 AM
kens_74_911s's Avatar
Plug
Sent you a PM, have a plug from this pan.
If I sell the drain Plug; I will lower the price on the pan + dipstick to $45 + shipping at cost
Ken - ebay: wandrey1 , *0 , *00 , *01
74 911s NA Widebody /96 BMW 750iL /99 BMW 328i/ 2018 BMW X3
81 VW Caddy Pickup X2 now...
84,85x2 .86,87,944. 82-924,88-924s parted with inventory!
68, 70, 72, 73, 911~ 70,73 914 past P/cars
Old 06-09-2015, 06:05 AM
ASE Master
alfadoc's Avatar
Coolant drain. Not oil.
Old 06-09-2015, 06:16 AM
Hmm sorry I misread, I have this short block I don't see any coolant drain plugs if you see it here let me know. Maybe you are looking for the Coolant Bleeder in the upper aluminum goose neck casting?
K
Old 06-09-2015, 06:23 AM
Pretty sure it's just a regular 8mm/13mm hexhead bolt with a crush washer.
I'll confirm when I get home, I have 2 blocks laying around with the drain installed.
ken, the coolant drain is on the exhaust side of the block, middle of #4 cylinder, it's the 13mm hex bolt sticking out.
Old 06-09-2015, 06:55 AM
Top photo, left hand side above the oil galley?
Old 06-09-2015, 06:59 AM
Yes
Old 06-09-2015, 07:25 AM
ASE Master
alfadoc's Avatar
Precisely
1989 944S2 (sold after 11 great years)
1980 911SC Weissach (bucket list car)
1975 914 1.8 (future restoration)
1993 968 Coupe 6 speed (new acquisition)
Old 06-09-2015, 07:26 AM
ASE Master
alfadoc's Avatar
LOL, that probably explains why we can't find it. We'll give that a go.
Thanks a bunch!
Old 06-09-2015, 07:35 AM
Sorry for posting the part number for the drain. Look at 24 and 25 in the illustration. 8x16 and 8x14 for the seal.
Old 06-09-2015, 08:12 AM
This
Old 06-09-2015, 08:14 AM
ASE Master
alfadoc's Avatar
Oooh, you're good. You get the intrepid parts sleuth award of the day. Many thanks. I can't imagine driving one of these cars daily without the fine folks on this forum.
Old 06-09-2015, 08:49 AM
I spent a day looking for the exhaust side heat shield in the pet...got fed up and riveted the spot welds. There will be some thread in 30 years with the title 'look what this previous owner did'
Old 06-09-2015, 09:05 AM
Hs
No spot welds here on this 86 shield. LMK if anyone needs it $15 Shipped.
K
Old 06-09-2015, 03:54 PM
It is the one that snakes behind the oil filter down to the lower balance shaft housing. It mounts (or used to mount) with two Allen heads above the oil filter housing..it is two parts or 4 in my case))
Thanks though...I appreciate it.
Old 06-09-2015, 07:08 PM
kevingross's Avatar
Block drain is a plain hex head bolt, M8 x 16 mm, 900-075-087-02, seal ring is 8 x 14 mm, 900-123-105-30. Don't over-torque. (This block drain was deleted from the 3.0 litre engines because of changes in the cylinder jacket layout.)
Kevin
Catellus Engineering
catelluseng@gmail.com
http://www.catellusengineering.com
https://www.facebook.com/catelluseng/
Old 06-11-2015, 11:56 AM
