ASE Master
Block Drain P/N?
I need to order a new block drain plug and sealing washer. My young assistant seems to have misplaced the one on our 84 resurrection project. Can't for the life of me find it in the PET. Can anyone assist?
Many thanks!!! |
944 107 197 01 and 900 123 118 30 from illustration 101-15 in the S2 pet? (101-10 in the 84 model...same numbers)
Plug
Sent you a PM, have a plug from this pan.
![]() ![]() ![]() If I sell the drain Plug; I will lower the price on the pan + dipstick to $45 + shipping at cost
Ken - ebay: wandrey1 , *0 , *00 , *01 74 911s NA Widebody /96 BMW 750iL /99 BMW 328i/ 2018 BMW X3 81 VW Caddy Pickup X2 now... 84,85x2 .86,87,944. 82-924,88-924s parted with inventory! 68, 70, 72, 73, 911~ 70,73 914 past P/cars |
ASE Master
Coolant drain. Not oil.
Hmm sorry I misread, I have this short block I don't see any coolant drain plugs if you see it here let me know. Maybe you are looking for the Coolant Bleeder in the upper aluminum goose neck casting?
![]() ![]() ![]() ![]() ![]() K
Pretty sure it's just a regular 8mm/13mm hexhead bolt with a crush washer.
I'll confirm when I get home, I have 2 blocks laying around with the drain installed. ken, the coolant drain is on the exhaust side of the block, middle of #4 cylinder, it's the 13mm hex bolt sticking out. |
Top photo, left hand side above the oil galley?
Yes
ASE Master
1989 944S2 (sold after 11 great years) 1980 911SC Weissach (bucket list car) 1975 914 1.8 (future restoration) 1993 968 Coupe 6 speed (new acquisition) |
ASE Master
Thanks a bunch!
Sorry for posting the part number for the drain. Look at 24 and 25 in the illustration. 8x16 and 8x14 for the seal.
This
ASE Master
Oooh, you're good. You get the intrepid parts sleuth award of the day. Many thanks. I can't imagine driving one of these cars daily without the fine folks on this forum.
I spent a day looking for the exhaust side heat shield in the pet...got fed up and riveted the spot welds. There will be some thread in 30 years with the title 'look what this previous owner did'
Hs
No spot welds here on this 86 shield. LMK if anyone needs it $15 Shipped. ![]() ![]() K
It is the one that snakes behind the oil filter down to the lower balance shaft housing. It mounts (or used to mount) with two Allen heads above the oil filter housing..it is two parts or 4 in my case))
Thanks though...I appreciate it. |
Block drain is a plain hex head bolt, M8 x 16 mm, 900-075-087-02, seal ring is 8 x 14 mm, 900-123-105-30. Don't over-torque. (This block drain was deleted from the 3.0 litre engines because of changes in the cylinder jacket layout.)
Kevin Catellus Engineering catelluseng@gmail.com http://www.catellusengineering.com https://www.facebook.com/catelluseng/ |
