Bradical's Avatar
LR Stainless fuel hoses
I put the stainless steel braided fuel hoses from Lindsey Racing on my '87 944 and I loved them. Does anyone know if this same kit would work on a 924S? I emailed LR and havent got a reply back. I am not sure if they are going to be long enough.
PCA - Florida Citrus Region
Old 06-15-2015, 04:57 PM
MDH MDH is offline
Yes....
BUT....to make enough space by brake booster the fuel line clips must be removed to bend at rear of car.
This was the worst part of the project!!
Do not try to pry the clips, the pins they are set on may break......cut the clips.
Pelican has the correct clips....order the clips that tell you they may not fit 924s.....they are the exact replacement.
I'll get p/n.
Cheers
1988 924S
It's still cheaper than psychotherapy...................
Old 06-15-2015, 05:13 PM
MDH MDH is offline
Part number for line holder is 944-356-591-00
Order 5......... $1.75 each
Another thought...I pulled intake manifold to gain more space.
Intake manifold gaskets 944-110-163-05-M 17
4 required.... $1.75 each
Have fun!!!
1988 924S
Old 06-15-2015, 05:21 PM
MDH MDH is offline
One more thought...when you cut old fuel line, cut as close to transition fitting as possible.
1988 924S
Old 06-15-2015, 05:23 PM
Bradical's Avatar
Thank you very much!!
Old 06-15-2015, 05:36 PM
MDH MDH is offline
You are welcome.......
it's good to have fuel go into engine, not onto engine.....
Cheers
1988 924S
Old 06-15-2015, 06:01 PM
Bradical's Avatar
So you are saying every fuel line clip from the engine bay back needs to be cut and replaced?
Old 06-15-2015, 07:32 PM
MDH MDH is offline
Pretty much.
I removed the clips until I felt comfortable that I had enough space to make the cuts
and get a wrench on the compression fittings. I think I was able to leave the clip just forward of the bend that goes toward the filter. If I recall correctly.
The steel fuel lines are quite rigid.
PITA does not do it justice...........
1988 924S
Old 06-15-2015, 09:41 PM
More Boost!
Bradical, did you replace the lines from the tank all the way to the FPR? I am considering doing the same thing with my crusty fuel lines.
FUEL RETURN LINE at LINDSEY RACING - Your Porsche Performance Parts Center
Old 06-16-2015, 06:02 AM
Bradical's Avatar
No, I didn't replace the hard lines, just the old rubber hoses and the rail jumper.
Old 06-16-2015, 07:45 AM
hey brad, working on the 924S? here is a "thumbs up" for a talented, skilled porsche addict. bought his 87 944 na and drove it 1000 miles home and it was everything he said it was great running car and a great seller. thank you sir, good luck have a great day an GOD BLESS.
bob
Old 06-16-2015, 09:28 AM
Bradical's Avatar
Ha, thanks Bob! Yes, the 924SE is in awesome order but there is a lot of stuff I want to get done with it before the autocross season starts back up.
Old 06-16-2015, 10:28 AM
More Boost!
Ok, good to know. Thanks much.
Old 06-16-2015, 03:26 PM
Bradical's Avatar
Originally Posted by MDH View Post
Pretty much.
Still sounds worth it to me. I sincerly appreciate your advice and those part numbers. That'll be my next project for sure.
Old 06-16-2015, 07:15 PM
Bradical's Avatar
I am finally getting to this. Thanks again MDH for the part number and advice. You probably saved me a bunch of down time!
Old 08-16-2015, 10:02 AM
