-   -   starter issue - no noise (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/872187-starter-issue-no-noise.html)
dunl 06-25-2015 02:59 PM
I just tried to start my car, and luckily I was on a hill, because when I turn the key there is nothing. Nothing at all. Seems to have lots of power, windows roll up and down fast and easy.
Dead.....solenoid? starter? contact?
Thanks.
mytrplseven 06-25-2015 06:06 PM
Possible starter, ignition switch, loose connection on starter, battery voltage low (even thought windows work, low draw item). Put a volt meter on the battery and check the connections.
fiily 06-25-2015 06:12 PM
Thanks.
As mytrpl has mentioned, your battery might be weak, have it tested at your flaps(friendly local auto parts store) and go from there. If the battery is strong go here ----> remove starter, bench test it. Clean your grounds also, bad grounds cause multiple(no start, hard start, funky gauge readings, aka electrical gremlins) on our 25+ year old car's wiring.
Weak battery replace and see if that fixed it.
dunl 06-26-2015 10:34 AM
And it started up again last night after sitting for half an hour, no issues. Started again this morning, no issue. Weird.
fiily 06-26-2015 10:46 AM
So, your battery sounds fine, clean your grounds, free and easy to do, minus the bellhousing grounds. :o
Let us know your results when you have free time.
