 Solid-State DME Relay- Beta Testers Wanted
		I have been developing a new DME SSR (Solid State Relay) for the Porsche 944/968/924S/964/968/993, and now have prototypes ready for beta testing. Only four of these are in existence and I am looking for Porsche enthusiasts in the Phoenix area who drive one of these cars as their daily driver to test one. If you’re interested, please sent me a PM. Keep in mind, these are not production units, there are a few of changes that will be made on the final version. All of these changes are very minor, the most significant being the small green wire (look closely in the picture). Once production units are ready, I am going to need these prototypes back, but I will give you a shiny new one out of the first batch for helping me test.
	Here is a picture on the new Solid-State DME relay next to a factory DME relay: http://i284.photobucket.com/albums/l...psb7f0enz7.jpg Some Information about the new Solid-State DME Really I think everyone is aware the OE relay suffers from various issues that cause no-starts and other erratic and shall we say “interesting” behavior. Lots of guys, including me, keep a spare relay in their glove box just in case. And I suppose I could have just bought a new OE relay form Porsche or one of the OEM or aftermarket options. But I am basically a 944 junkie with an engineering degree, so enviably I was going do a full redesign and make it better. The main issue with the OE relay, in my view, is cracked solder joints. The reason this happens is because the mechanical relays are made of metal which is heavy. Combine that with several amps of heat, constant engine vibration and one to three decades of driving… Yep, cracked solder joints. Even if the joints are re-soldered they will eventually crack again at some point in the future. But that’s assuming the relay armature and contact points don’t wear out first. In comparison, this new Solid-State DME relay is less than half the weight, which will preserve the solder joints indefinitely. Plus, it has no mechanical parts or contacts and therefore cannot “wear out”. And because I have way too much time on my hands, I went ahead and put in a timing circuit in it that primes the fuel pump for two to three seconds when the key it turned on. This is a standard feature on most modern cars because it helps bring the fuel pressure up before the DME/ECU starts firing injectors. It's a handy feature if you have opened you fuel system and want to bleed out the air without cranking the engine. And a nice no-start troubleshooting aid because you can faintly hear the fuel pump cycle on KOEO. I welcome everyones input, so please don’t hold back with the question and/or comments.  |
 That's pretty cool!
 Great work.
	In your spare time, can you develop a nice DME like rogue's?  |
 Nice work!
	I'd like to test one out for you. I live in Scottsdale and also in Southern California. I drive often between the two locations, so I can give it a real long test experience for you in my '86 n/a. I hate dealing with the mechanical DME relay. I've had even new ones go out on me in the long hot drive from Scottsdale to SoCal. I'm looking forward to your alternative!  |
 Great work!  Any idea f how much testing you want to give it. Or when do you think these will be ready for sale and at what price point?
 Let us know when they are for retail sale - thanks.
 I live in the Phoenix area and would be willing to beta test. Unfortunately my car is not daily driven though.
	The fuel pump feature has me very interested. Also the fan relay sounds good. Hope this becomes available.  |
 Unfortunately I'm in PA but my '86 N/A is a daily driver so if your looking a bit further afield I would be happy to test one for you.
	Hope it all works out well as I would be interested in removing the weakest link from my car. Cheers, John  |
 The fan relay and the Blower resistor pack do seem like good targets for development and don't overlap with existing products.  |
 As an electrical engineer also, and I say WELL DONE !
 Wow!
 Depending on price, Ill take 3.
	Yes, I have a spare relay for 2 of the cars, plus a few I saved that failed or may have been failing.  |
 Happy to test an NA unit (race car) or 951 unit (project car).
 Do you want to test on a RoW car? :D
 Wow, impressive!
	I will be monitoring this project for final availability and production. Kickstarter for production funding?  |
 PM sent!
 I'm in gilbert, I'll toss one in my car to test it once I get the damn thing running again!
 I want one!
 I'm not in the Phoenix area, but USPS is cheap!  I daily an '84 944 and would be happy to help with beta testing.
 Subscribed.
	Any interest in developing a 931 FPR?  |
 I'll volunteer my 1984 944 NA for your project.  I do however live in Hannibal, MO.  It might be nice to test your product in a different climate setting than Arizona.  Believe me - it's a "wet" heat here.  Thanks for your consideration.  :p
 It doesn't look like he has been on PP lately. I just hope that's because he's hard at work making the relay.
 Any more news on this? If it works in down for a pair. Sick of rebuilding my relays.
 Following this with interest
 I will take one when they are ready.  Joel
 Update
		The Solid-State DME relay project is alive and well, all of the Beta Testers are reporting back with no issues. The design has been finalized and we are moving into the production phase. I will reserve a relay from the first batch for everyone who requested one prior to this posting. I am estimating the first production units will be available in one to two months.
 Sounds great! Am looking forward to buying one of the relays. Thank you for all your effort.
	Is the timing circuit that primes the fuel pump still part of the design? Also was wondering.... Since the Rogue NA-Tune seems to be "dead in the water" would you be considering putting some of those into production?  |
 Awesome! Sign me up for one of these... I'd love to never have to worry about it again. Stupid relays...
 This is phenomenal!  Subscribed and awaiting pricing!
	Well done and THANKS!  |
 Just an FYI... there is a guy out of silicon valley selling solid state DME relays. He is supposed to be a firmware engineer who is also a Porsche owner. I'll see if I can get his info and post it on Pelican.
	Cheers  |
 If you want to announce someone else's Solid State Relay please do it on a separate thread.
	Thanks!  |
 I'd be interested in purchasing as well, awaiting pricing and availability!
 I have been in contact with Ftech9, and will most likely be selling his relays on my website as well. He IS still working on them, and a price is not yet set. Things like this take a lot of work to make, and a lot of time to produce. But he is working on them, and I don't think we have too much longer to wait.
 Solid-State DME Relays Now Available!
		I am pleased to announce the Solid-State DME Relay is now for sale at Focus 9 Technology, LLC. It is available as a stock replacement or with the additional “Pump-Prime” Feature. I would like to thank everyone for their interest and support in making this product a reality. I hope this will be the first of many new products to come.
 Hrm. Just got the notification of this post by email, and they're already sold out? When will the next run be?
 Installed my new SS relay with the Pump Prime today and it works great. Love the Fuel Pump Prime feature. My car now starts in about 1 second of cranking instead of 2 - 2.5 seconds.
	Judging by the carbon on the contacts of the old original relay it replaced I am glad to have made the switch. Thanks much Joel. PS Any chance there might be a Rogue NA Tune coming???  |
 I'm definitely interested in one or two.
| All times are GMT -8. The time now is 07:23 PM. |
