Now that's some good info. Thanx again!
The more you practice the easier it gets ;) J_AZ |
...and if you want the best cooling if switching to R134a Porsche 944 AC Condenser 94457301101 Where ever you get the expansion valve, double check for correct part. I ordered locally ---number & picture matched and was sent the wrong part. GL J_AZ |
^^^^^^^ John. Not trying to be a Richard here, but what would that condenser do? 3-4 degrees at the vent? 500 bucks is a lot of coin for a little extra comfort, and probably only on the hottest days. Or do they have a graph which shows the benefit? I haven't researched it, but when I get my 944 it will definitely be converted to R134.
Griffiths would have the technical information on the dual core/parallel flow condensers.
Most newer vehicles have the upgraded condensers. They are more efficient. In an older vehicle, with the AC system in OEM condition, switching from the OEM to the upgraded condenser you could expect up to ~ a 1/3 cooling improvement with R 134a. I do not have the technical information on the 944 condenser. John |
Anywhere near 1/3 improvement in efficiency would be an amazing upgrade.
Yes, I agree.
But understand, the upgraded condenser can only do its best if the entire system has been checked. The other flaw is that if your compressor fails due to "Black Death", the tubes in the new dual/parallel condenser will clog--they are a lot smaller than 944 original condensers. Once they clog it is almost impossible to remove ALL of the filth from the compressor. Expensive repair. J_AZ |
Ahhhhh...there's always a 'but........'
I have not done anything yet. Here is some more info that may pinpoint the problem. When I start the car and turn the A/C on it blows cold for about 30 seconds then just outside temperature air. If I turn off the A/C and shut the engine off and restart it 15 minutes later and turn the A/C on, again it blows cold for 30 seconds, sometimes a few minutes then warms up again. Any thoughts? |
I reread Griffiths post and would begin with his advice.
My (secret-ha) source for troubleshooting is my local supplier and forum: Automotive AC Information Forum - ACKITS.COM GL J_AZ |
I read your first and last posts, skimmed the rest.
The system was in an unknown state, presumably empty, or near empty because it has a leak. You decided to add 28oz of R12, and the system ices up and the sight glass is foamy. My intuition tells me you are under charged. Your system holds 40.6 ounces of R12. I suggest you recover the R12, change the schraeder valves on the high and low service ports, vacuum the system, check to see if it holds vacuum, then add the proper amount of refrigerant. I would also check for leaks around the clutch on the compressor. Oily, dirty, grimey black crap indicates a shaft seal leak. Good luck!SmileWavy |
Hi Matt, The A/C was working fine blowing cold, occasionally it would blow kind of warmer but in a minute or two it would blow cold again. A week ago it stopped blowing cold so I figured it needed Freon. I added two 14oz cans and one of them had red leak detector dye. I see no leaks anywhere, only place I have not checked yet is under dash. The low pressure switch by the receiver/drier is good and the compressor runs so I assume it has enough charge. Also when I start it it blows cold for a minute then warm. If I restart in 15 or 20 minutes, same thing again, blows cold for a minute then warm again. |
Close the heater valve manually. It's at the back of the motor in the center. You might need a screw driver to use as a lever to close it. The other thing I would check is the valve that closes the barn doors. There are two, one passenger side, one drv. side. Check the suction from the vacuum lines. Last resort, check the vacuum reservoir, the green thing under the hood, for leaks.
| All times are GMT -8. The time now is 08:41 AM. |
