Shepper's Avatar
Manual Steering Lube - ?
83 944 N/A
When I was last under my car, I noticed that there was a small plastic threaded plug in my manual steering rack. While I was wiping the grease off of it (it was completely covered) it broke off. So, I removed the rest of the plug with a screw driver and I'm planning on replacing it with a metal bolt.
My question is...
Should some sort of fluid or lube have fallen out of that hole when I removed the plug? Mine was totally dry. I assume that it's there so you can grease the rack or something.
What type of lube should I push in there before I replace the plug? Or, should I not add anything?
Old 11-18-2002, 09:47 AM
No, that plug is only removed when a wheel alignment is carried out. There is a special tool that screws in there and locates the rack in a central position. The plug thread length is very short so make sure the bolt you use does not push against and jam the rack.
As far as grease goes, probably a good multi purpose or moly grease will work fine. Just make sure there isn't any dirt or grit in the rack.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 11-18-2002, 10:36 AM
