sjv sjv is offline
S2 air filter hidden
The air filter compartment looks like it's buried in the nose is disassembly required
Old 08-13-2015, 03:23 PM
jhowell371's Avatar
Yep.
Red 84 w/25,xxx miles
Stone Gray 89 S2 w/90,xxx miles
Old 08-13-2015, 05:13 PM
Yes particularly the sneaky bolts by the headlights:
Nose Panel - Removal and Installation
1987 928S4
1992 968 cabrio
2009 957 Cayenne GTS
Old 08-14-2015, 07:35 AM
Welcome to three dimensional world of Porsche wrenching!
Good luck, George Beuselinck
Old 08-14-2015, 07:43 AM
Take your time, it's a bit tedious, but fairly straight forward.
Old 08-15-2015, 06:54 PM
911tracker85's Avatar
so this insanity with hidding air filters did not start recently with Porsche? I dont have an S2 (944S and a 951) so have not encountered this. when I saw the video about having to dismantle most of the rear of the newer 911 just to change the air filter, in addition to having huge margins on the new porsches figured porsche wanted to increase the revenue/margin for their repair department.
pics?
Bob Cox
78 930 clone project car.
87 924S resurrect at some point.
84 928S, Ruby Red linen/brown interior - sold
86 944 turbo my new DE/track car - sold
Old 08-16-2015, 07:34 AM
Just thinking out loud
mattdavis11's Avatar
Imagine if the nose panel was welded, like the early cars. That would make it really tough.
91 FJ80
84 Ram Charger (now gone)
Old 08-16-2015, 02:31 PM
9FF 9FF is offline
9FF's Avatar
I don't even bother putting those bolts back in and I cannot see a function for them, except to make the panel more difficult to remove. That panel is held on with 8 easily accessible fasteners, those extra two fender bolts don't make a difference.
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 08-16-2015, 04:22 PM
"8"? Besides the 8 mentioned and the 2 fender bolts, mine, and I suspect more than a few others also have a single sheet metal screw on either side of the crest that also holds the panel to the outside boundary of the intercooler boxed space.
Old 08-16-2015, 07:13 PM
9FF 9FF is offline
9FF's Avatar
Even so, those 10 fasteners will take you a total of 2 minutes tops to put in, whereas the two at the fenders alone will take you 30 minutes. On the plus side, you will invent new curse words and probably some new yoga moves while reaching under and over the fender at the same time
Old 08-17-2015, 12:32 PM
I've had a couple S2s and bad the nose panel off of each. I do not recall it being too hard. Might have odd panel gaps or rattles if it's not put all the way back together.
1987 928S4
1992 968 cabrio
Old 08-17-2015, 03:07 PM
Even so, those 10 fasteners will take you a total of 2 minutes tops to put in, whereas the two at the fenders alone will take you 30 minutes...
Cant you just rotate the panel up without removing the fender bolts?
Old 08-17-2015, 04:48 PM
Bradical's Avatar
I just used velcro for my nose panel. Thinking about doing the same for the exhaust to make the clutch job a little quicker.
PCA - Florida Citrus Region
Old 08-17-2015, 06:03 PM
"30 minutes"? Maybe there is a difference across the years. On my 89, pop up the headlights, get screwdriver 1/4 drive with a small wobble extension and a 10mm socket. insert. and remove. About 30 seconds a side on my car....
Old 08-18-2015, 05:10 AM
1/4" ratchet, 4" extension, 10mm socket.
Old 08-18-2015, 09:47 AM
9FF 9FF is offline
9FF's Avatar
There must be a difference across the years, all mine have a bolt and a nut so you need to secure the bolt head while turning the nut. Needs two people, one with small hands. Also, the wheel liners need to come off. I've done it myself but it is a hassle.
Old 08-18-2015, 12:06 PM
On my 85/2 the bolt is part of the fender.
Old 08-19-2015, 04:28 AM
now I am sure your comment on the thread about the clutch job is a joke.
Bob Cox
Old 08-20-2015, 05:45 AM
