What would Darth Vader do
Fuel Gauge readings?
I haven't seen where anyone has a properly reading fuel gauge. Does anyone have one and if so, what did you do to get it correct? Replacement part numbers would be a plus..
1983 944 (2002 to now) 3-924's (Sold) 1967-912 (Traded) NEVER put a used water pump in your car... |
Mine works fine.
Many times it is the grounds behind the instrument panel or the grounds on the gauge itself (the little black football things on the 85.5+ cars) also check your ground in the rear hatch, plus electrical connections at the sender. Senders don't really go bad all that often. AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
