"Ferdinand's finest"
loweing the front of a 951
pretty sure my suspension is stock up front in my 88 944 turbo other than koni shocks.
what is a simple and cheap way to lower my car about a half maybe a tiny bit more. cant afford to go any lower with my tire setup Cheers! Drew
"The fastest lap time you will ever record, will always be done behind someone else" - Yours truly |
Change the springs. Some of the aftermarket springs are a little shorter to bring the nose down a half inch or so. I"m not sure of which ones do this but it's usually stated in the springs specs.
Weltmeister 200 and 250 lbs springs are shorter and stiffer than OEM ones. They should be direct fit.
The Welt springs are about 1.25" drop.
Misunderstood User
Yes they will but.......are you leaving the rear height stock?
Jim 1983 944n/a 2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway |
Free shade tree methods would include cutting parts of the spring off, heat, gasp chains. lol
Buy the weltmeister. I ran them and do not like them, however, personal taste.
dolor et pavor Copyright |
Kessel run in 12 parsecs!
That Guy
Assuming the rear has never been adjusted, you can usually get about .5 - .75" drop by adjusting the spring plate.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
If you don't plan on adjusting ride-height very often, you can just cut off the lower spring-perch (as close to strut as possible). Then just re-weld it back onto the strut at about 90% of the height-reduction you want.
