p-talk's Avatar
Quick Tip: don't forget to check the clutch pedal free-play
I re-adjusted mine today, and my shifting is back to normal (i.e smooth). It had started to shift hard, and it took me awhile to figure out why. It had been two years since I adjusted it. Haynes says 3mm is good.
1984 Porsche 944 - Mathilda the needy
2014 Audi Allroad - daily driver
Old 12-30-2011, 04:15 PM
porschetub's Avatar
Haynes Manual
Never been a fan of the Haynes manual,missing a lot of info and not very accurate.
I have Haynes manuals for my other cars and just seem heaps better than this one
Personally I run more than that ,3mm isn't much really ,can anyone else comment?
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 12-31-2011, 07:40 PM
Custom User Title
mikepellegrini's Avatar
I'm not sure where Haynes gets the 3 mm.
The idea is to get a small amount of slack (.5mm) between the rod and where it pushes on the piston in the master cylinder.
From the Porsche Shop manual:
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 12-31-2011, 08:41 PM
Send a message via Skype™ to massive
When you say slack do you mean the pedal should be floppy or slack as in when you feel the resistance on the pedal increase as you push down. My pedal isn't floppy but you can definitely feel the resistance increase after you push it down about an inch. Anyone know if this correct?
1984 944, 2.5L, manual transmission, UK right hand drive.
http://944foot2thefloor.blogspot.com/
Old 01-06-2012, 12:03 PM
p-talk's Avatar
Exactly - that Porsche shop manual page also says 3mm at the pedal.
Old 01-06-2012, 01:23 PM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
Someone told me once that if you roll up the Haynes Manual one could use it for a wheel chock - doesn't work their either.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 01-06-2012, 01:35 PM
Think of it as pedal slack you can feel with your big toe. An inch is excessive but 1/8" to 1/4" is about right when warmed up. If there is no slack when the car is warmed up then the clutch might slip and wear the clutch disk.
You do not want to have too little or no play play here because you will burn out your clutch.
Old 01-06-2012, 06:26 PM
Toofah King Bad
Rasta Monsta's Avatar
Also, this is not something that should need frequent adjustment. If it does, there is a problem with your hydraulics.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 01-07-2012, 09:59 AM
p-talk's Avatar
True. I had replaced both the master and slave cylinder when I last checked it. Had forgotten to check it since - should have checked it at around 3-6 months after replacement.
Old 01-07-2012, 03:15 PM
porschetub's Avatar
Well said, have 2 other Haynes manuals and they are very good ,what about all the "visit your nearest dealer" BS,you don't buy a manual to read that .
So whats the consensus on the freeplay??
Mines around 6mm @ the pedal and shifts fine on a clutch with 2mm left on the plate and good rubber centre,works for me.
Old 01-07-2012, 08:26 PM
Here's a video of the clutch pedal on my 944. As you can see there's no pedal wobble or what I would call slack. However watch my hand press the pedal down and notice I have to press it about 1-2cm's before I feel any real resistance. Just wanted to know if this is normal?
Old 01-20-2012, 05:30 AM
Send a message via AIM to sempaipaul
I have the same thing. Also curious if this is normal?
Paul
03' Audi RS6; 16' 328i xDrive Touring; 13' X3 mSport, 91' e30 M52
Old 10-20-2015, 06:19 AM
Watch the slave cylinder after adjusting clutch pedal free play. You can get leaks because the slave will be moving in a new range of motion and its piston may run up against a rusty cylinder wall. Kind of the same thing that happens when the clutch is replaced.
I'd adjust the free play if it too large and that was causing shifting troubles. I just wouldn't go off on a long trip without making sure the slave will hold. Or just replace the slave.
Peter
Old 10-20-2015, 05:03 PM
Volhv's Avatar
I just took a look at mine, and tried adjusting. A bit difficult to feel the exact point of cylinder engagement because the pedal is spring loaded. I'll pop the pin out that connects the master to the pedal, that way the spring force of the pedal will be taken out of the equation.
1986 944 NA Sapphire Metallic
http://944porsche.blogspot.ca/
Old 10-21-2015, 06:34 PM
Tags
clutch pedal adjustment
