Collapsing the collapsable spare
Bit of a funny issue...
I recently picked up a 924S and the spare tire had just been used so was inflated. I emptied the air from it, and it won't actually collapse even after leaving it for a few days. I'm assuming it's just due to age, and that the tire is probably no longer usable as it has lost elasticity.
This is just about as small as it will get.
Has anyone else experienced this?
I've not seen one with two fill valves before:
Any ideas why it has two valves
Old 11-16-2015, 04:12 PM
jhowell371's Avatar
Two valves to allow monitoring air pressure on one while inflating would be my guess. Try putting a ratchet strap around the tire's circumference and cranking it down.
Red 84 w/25,xxx miles
Stone Gray 89 S2 w/90,xxx miles
Old 11-16-2015, 05:31 PM
930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
I tried to pull a vacum on the one for my 944 but it will not fold right. If You find a fix let me know.
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
YOU have to put your weight on it and help it fold back down while fully deflating.
every few years i pull mine out and inflate it to make sure it still holds pressure.
Old 11-16-2015, 06:23 PM
https://www.youtube.com/watch?v=JcVJ4Sp6Pao.
1988 Silver 924-S Original owner
Porsche 924S: The 944's cheaper, faster little sister.
Old 11-16-2015, 06:26 PM
Thanks all
I tried sitting on it while deflating it. I'll try a ratchet strap, that's a good suggestion.
Old 11-16-2015, 08:18 PM
Use your valve stem tool to remove the internal workings of both valve stems. Have a friend help you squeeze the tire back into shape....may need a ratchet strap as well.
Old 11-17-2015, 03:57 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
If you can't get someone to help, wrap a rope around the center of the tire and with a piece of pipe or strong wood like an axe handle, twist the rope (making the diameter smaller) and that will pull the tire into position so you can put the valve stems back in.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 11-17-2015, 07:34 AM
West Central Ohio 45380
plyhammer's Avatar
Wrap a tie down strap and crank it tight
www.plyhammersparts.com
Old 11-17-2015, 08:24 AM
