Vehicle Enthusiast
Gauge reading bounce up under load
I've finally decided to tackle the electrical bugs in my 944
Whenever i put the system under load- headlights, heater, stereo; some of my gauge reading will bounce up, until the electrical load is taken off.
For instance, when the car is at almost 3/4 temp, and i turn on the heater while the headlights are on- the temp gauge bounces up into the overheating range (though it is not actually overheating).
My oil pressure gauge bounces a little too as well at the same time.
Few repairs i already have done:
0 gauge wire from battery to alt and starter
new battery
new alternator
all chassis ground have been cleaned of corrosion- including corrosion inside the wires
Anyone know what might be the cause of this?
84' 944- 115K M220 M456
Old 12-28-2015, 11:21 AM
Ck...your main battery ground wire that bolts to the back of the block ... it may be frayed and shorting out due to being old and hot!
Ron
Old 01-01-2016, 05:09 PM
Vehicle Enthusiast
Ron
It was corroded, i've already replaced this with 0 gauge wire too.
Old 01-01-2016, 07:11 PM
Tags
electrical bugs
