-   -   started stripping, and good vibrations (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/89726-started-stripping-good-vibrations.html)
jglover 12-04-2002 02:48 PM
hi guys, thanx for the replys about the spacers, will order some this week, stripped the interior out of the car today ready for the respray, all the carpets seats door cards,trim seat belts etc. found lots of water under the carpets so some new seals seem to be in order, also i will check that the sunroof pipes are not split, i am also fitting a centel locking kit and new alarm which i will link to the c/l system, also the vibration seems to be at low revs i have double checked the balence belts and seem ok, when the engine hits the power band it seems to smooth out, any help will be as usual greatly appreciated thanks. john
Trevor 12-04-2002 03:29 PM
How are your motor mounts, does it smooth out around 12-1600 RPM's, could be dirty injectors. Good Luck, lets see some pics of the process if you get a chance.
