-   -   Port and header sizing for 968 ?? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/897595-port-header-sizing-968-a.html)
333pg333 01-06-2016 03:23 PM
Does anyone happen to know or have to hand a 968 head and headers that they can give me the inner diameter of the exhaust port and headers please.
robert_hooper 01-07-2016 11:37 AM
I can check tonight for you, Cheers Rob
thomasryan 01-07-2016 01:51 PM
I have an exhaust header sealing ring that measures 1 and 7/8 inch (about 48mm) internal diameter...if that helps.
333pg333 01-07-2016 03:23 PM
Thanks Rob.
Thanks Thomas, it would be smaller than that. More likely 41mm port and 38mm I.D. runners but I am just wanting to get a correct measurement if possible.
robert_hooper 01-07-2016 06:56 PM
Port size is 40mm Exhaust is 41mm.....
333pg333 01-10-2016 03:24 PM
Thanks very much Robert!
v2rocket_aka944 01-12-2016 09:11 AM
Patrick hope you don't mind me jumping in but seeing as your question was answered...
Could any of you folks with a 968 head handy, measure the dimensions of the INTAKE port?
I assume it is larger than the 944S/S2 port, but just how much bigger?
333pg333 01-12-2016 01:30 PM
No worries Spencer. I don't have that measurement handy either. I Don't need that but you should be able to find it easily enough.
I was inquiring about this trying to figure out what size to make new primaries and dual X overs for a twin scroll EFR turbo. Quite technical as it turns out.
Now we're going to put new motor into current setup (headers, Xover, Exhaust, GTX35) and see what it gets us. Cheaper and faster to get back on track this way. After that we can make better decisions of where we need to go....I hope. :-)
333pg333 01-12-2016 06:19 PM
Actually I have it at 58mm x 52mm ...but that might be on a modified head.
Hmm, now I have seen an email from Duke saying the stock 968 ports are 56x44mm.
robert_hooper 01-12-2016 10:58 PM
My intake is ported so I cant comment.... Sorry,
