overkill's Avatar
Send a message via AIM to overkill
This is the day,...
Ok, lets start the day with,... what is ATF lube? I know that ATF usually means Automatic Transmission Fluid.
{1987}944S - (SOLD).
Old 12-09-2002, 07:27 AM
AFJuvat's Avatar
thats what it means, automatic tranny fluid
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 12-09-2002, 07:33 AM
overkill's Avatar
You want me to lube the injector o-rings with auto tranny fluid? AFJUVAT, did you see the last replies I made in my last thread about timing? What do you think? Did I do it right?
Old 12-09-2002, 07:42 AM
justin's Avatar
Yes use ATF to lube injector o-rings,works great. Also you can use vasaline,just a very little though.
Good Luck
Texas hosts the 928 Owner’s Club OCIC in 2009
www.928ocicdfw09.com
1980 928 5 speed and a few mods..........
928 OC member
PCA member
Old 12-09-2002, 07:50 AM
overkill's Avatar
OK, my car is DONE!!! I can't believe I actually finished!!! All I have to do now is replace fluids and then,... start her up. I'm scared. OH, I went to install the spark plug wires and found out that I had labeled them in the wrong order when I removed them from the car,... when the car wouldnt start the last time!?!?!?
Old 12-09-2002, 09:44 AM
ae1969's Avatar
Send a message via ICQ to ae1969
You had the spark plug wires crossed the last time. That would explain the inability to start the car.
I hate to think you did all this for nothing.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 12-09-2002, 10:37 AM
88_944's Avatar
Yes, You have to use Auto tranny fluids on the o-rings. Start her up and let us know. Great job!
My Black 944
My Gaming Forums. Xbox360gen.com
Old 12-09-2002, 10:43 AM
overkill's Avatar
Yeah, I think thats why it wouldnt start the last time BUT, I do not regret doing all this. You see I found out that I needed a new CAT and O2 sensor. Plus, I know the top end of this car now. I know more about cars now than ever!!! Well, time to refill the fluids. Wish me luck.
Old 12-09-2002, 10:48 AM
overkill's Avatar
Well, she isnt starting She is crank over but its like there not enough power in the battery. I am jumping her using the truck but still, it sluggish. She is cranking over and I can hear hiss like pops out the rear. I do smell gas. But wont start. The battery is new but has been sitting for awhile. Should I go out and get a new one? What do you guyz think?
Old 12-09-2002, 11:42 AM
Scott R's Avatar
Check that little screw on your rotor. Sometimes it falls out and sounds like what your describing.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 12-09-2002, 12:41 PM
overkill's Avatar
What little screw in the rotor? The DIS ROTOR? Sounds like what the hiss popping?
Old 12-09-2002, 01:17 PM
