Greetings, I own a 944 1985/2 NA
Love it, but currently it's got me dumbfounded. The issue is that the engine bogs down when i try to accelerate, but in waves. It idles beautifully, but refuses to perform under load. I've replaced: Vacuum Lines All air hoses AFM (got a used one, so it's questionable) Fuel Pressure Regulator Fuel Pressure Damper Injectors Spark Plugs Spark Wires/Coils Speed Sensor Reference Sensor https://youtu.be/D-x1K74jlNg |
What is your fuel pressure at the rail?
Fuel filter, or the DME temperature sensor is faulty.
Mine would have very low power at heavy throttle inputs, turned out the bad sensor was making the car run really lean aka no power under load. Swapped the sensor, all was well with the world. |
Yeah based on the surging it could be a classic case of a lack of fuel flow. If the filter has never been replaced that's a sensible thing to do as well as the testing of the DME temp sensor, preferably at the DME in case there are wiring concerns. If it's still boggy you could try to install a fuel pressure gauge you can watch while driving to see if the pressure is constant or see if it will pass a fuel flow test. The fuel pumps are pretty robust but they can wear out. It's also possible (but not likely) that the in-tank prefilter is badly plugged, I think it's the 928 part 92820108104.
1987 928S4 1992 968 cabrio 2009 957 Cayenne GTS |
944 addict
Have you checked the catalytic converter? If it's plugged it can cause acceleration issues.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
Underside of J-boot cracked?
Red 84 w/25,xxx miles Stone Gray 89 S2 w/90,xxx miles |
Yeah.. If you've not replaced the j-boot, after 30 years, I recommend it.. Mine was split underneath. When I pulled it off, it came apart right where the flex bellows are.
944 addict
Mine, too, especially where the 1" vacuum hose is connected underneath.
www.rennwish.org '88 944 NA - Red/Black with more tinkering done than probably needed. |
The fuel pump and filter have been replaced, guess ill have to try the J-boot and temp sensor next
the boot seems to be in good condition, i've removed it multiple times in this effort to smooth things, and the weren't any visible discrepancies, but 30 years is long enough, i suppose... |
J boot might do the trick, seems like it's a vacume leak or a fuel pressure problem
Good and bad news, the catalytic converter is fine, car still tripping out... i'll post an update once the DME temp sensor arrives.
Toofah King Bad
How many volts when running? What kind of spark plugs?
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
What's your gas mileage / fuel consumption?
Clark's Garage explains how to check the following sensors:
* engine temperature sensor (as advised in previous posts) * AFM * Idle control valve/AAC * throttle position sensor/switch. You've replaced a lot of stuff, and spent a lot of money. But simply testing resistances with a multimeter can save a lot of cash...
1980 911 SC Metallic Blue Euro spec, 'Greta'; 1986 944 Euro spec Light Bronze Metallic, 'Sabine II' 1986 944 NA Euro spec Guards Red 'Sabine I' - RIP, gone but not forgotten 'Hell is previous owners.' (anon.) |
Given that its been 30 years, i figured replacing some of the parts wouldn't hurt. i've checked the DME temp sensor and it works fine, i've ordered another O2 sensor, figured it's about time it needed replacing either way. I can't exactly calculate the fuel consumption right now, i can't get it to rev steady to shift gears, so i haven't taken it out onto any main roads.
still hoping to hear the Big Solution to this one...
87 944 NA |
I had this situation once. I was like a dog chasing its tail. It turned out to be an arcing spark plug wire. At the time the symbology eluded me.
It still eludes me...
1991 cabriolet (sold) 1989 S2 1988 S 1987 944 n/a (sold) 1987 944 factory yellow (junked ![]() |
So I've replaced the O2 sensor and am still where I started, and not sure when I lost it, but oil pressure is now nonexistent, and it seems that the oil inst getting up into the valve cover.
Tags |
944 , engine , issue , vacuum leak? |
