Uh oh this is bad. Reference sensor mount broken
Trying to replace both speed and reference sensors. Unbolted, was prepared for it to be tight so imagine my joy when it popped right out. Until I realized why.
![]() What's my next step??? How did this happen?
1989 944 8V |
Proprietoristicly Refined
Curse the PO.
Probably was cracked earlier and finally failed. Post a WTB on the Pelican parts board. Should be reasonable-under $50. Ebay has a few as well. Reference sensor mounting bracket. COVER THE BELL HOUSING TIMING TDC HOLE WITH TAPE!! or you will drop a part in the hole. To remove the bracket there are 2 bolts with a trial and error test of tools. Very small hands help or prepare for many bloody cuts. GL J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
944 addict
Hard for me to tell from the pic, is this the speed sensor? It would be the one nearest the firewall. If so, make sure whether or not a shim (shaped like and "8") should be included when the sensor is re-installed. The turbo and some N/A models use one and should be installed if germane to your model for proper clearance from flywheel. See my pic to understand what happened to my car when the PO left it out:
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
No, it's the reference sensor. I had not tried to remove the speed sensor yet so I still don't know if there is a shim in there or not.
1989 944 8V |
... been there. I had to basically split mine to get it out. Rear most sensor cemented itself in place. It was the original sensor. The sensor closest to the block did use a sleeve on my '86. Don't forget to maintain the air gap upon reinstallation. The sensor blocks are reasonable pricewise...
86 951 blk |
That crack was probably caused by someone trying to pry the bell-housing off without removing the sensor bracket. From the bottom of the bell-housing up to there, that's a large moment arm to apply a lot of torque to that bracket.
dang .... I read some of these posts and consider how lucky I have been so far on my project cars. refreshing/restoring these old cars is hard enough without the extra frustration of this kind of stuff.
![]() my solution, alum HVAC duct tape. can handle the heat.
Bob Cox 78 930 clone project car. 87 924S resurrect at some point. 84 928S, Ruby Red linen/brown interior - sold ![]() 86 944 turbo my new DE/track car - sold
That other sensor has to come out and the cracked bracket removed and replaced. If the remaining sensor will not come out you will need to do some challenging cutting/wrenching/prying to get the bracket off. I removed the intake manifold and oil separator and repositioned a bunch of the wiring to get at mine and did some fancy cutting with a plumber's mini hacksaw.
There are a ton of posts here, do a search. We have all been there. Luck, Jon
87 924S 82 924-Gone. 80 924 parts car-Gone. |
I was able to purchase a new Reference Sensor housing from Pelican. They are out there. I did have to modify mine as it had a bit more of a tail. So we ground it off and it fit right into place.
Two questions - am I better off to remove the intake manifold before I start this? Will it clear more space for me to remove the bracket?
What's the best way to set the spacing? Is there a source for the 8mm shim? Off to start searching.
1989 944 8V |
More Boost!
Yes, remove the intake for more room, but before removing the intake mani. buy 4 new intake gaskets ($2/ea from pelican parts)so your not waiting around for days to put the intake back onto the car.
Cut up a phony card you get in the mail and slip it under the sensor to gap. Factory spec is .8mm +/-.3mm Some members will glue a thin washer on the reference sensor bottom and then remove it when gap is set. J_AZ
I have gapped flywheels that were not completely symmetrical, and have to watch out so that they don't chew up a sensor. (they had high & low spots)
dolor et pavor Copyright |
Thank all, appreciate the guidance.
1989 944 8V |
Good luck, George Beuselinck |
Just a decimal point correction - .8mm = .032 and not .0032 . (Actually .031496)
Had time to get back to this. I don't think this is what the factory intended.
The "B" opening is a larger diameter. Is there a sleeve on the sensor that is supposed to slide off? I didn't try too hard but that too didn't seem to want to come off. ![]()
1989 944 8V |
Yes - should be a sleeve in it.... I've got a couple of these - would sell one for $50 shipped.
89 944 - Alpine white/blue, Focus 9 DME and MAF, MSDS headers |
Don't use little L-shaped allen-keys. Not going to get enough torque. Use a 1/4" flex-cable extension. Last edited by DannoXYZ; 04-02-2016 at 12:01 PM.. |
