-   -   Replace late model ignition switch (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/908537-replace-late-model-ignition-switch.html)
GostRidr 04-01-2016 03:41 PM
I am about to rule out an ignition switch issue and realized that the clarks guide to replacing this does not cover the newer cars. Does anyone remember seeing a write up on how to change out the ignition switch in a NON 924S/early model?
kdjones2000 04-01-2016 07:22 PM
It's pretty much the same. Two screws at the back of the switch you need to remove.
dgcantrell 04-02-2016 08:26 AM
The best way is to remove the steering wheel and instrument cluster an access that way. Ask me how I know. You must use a very short screw driver to get the screws loose as there is only a couple of inches of clearance to get at them. A phillips screwdriver bit in a 1/4" socket with 1/4" drive ratchet was my weapon of choice. If your car has an airbag, disconnect the battery. On second thought, disconnect the battery anyway when doing this procedure.
