Alexb944's Avatar
Unhappy If it isn't one thing it's another..
So finally got the 944 back from the shop, they adjusted the shifter linkage and they said all is well.. Well when I went to go pick it up first of all I can find all the gears now which is.. Great. The only problem is now first and second gear doesn't seat well by that I mean when I put it in first it doesn't feel like it's all the way in gear and when I go I can go like 5mph before it sounds like it needs to be shifted.. So basically I need to go from first to third ad break lights...
Also now I'm getting a ton of noises that I didn't hear before all this loveliness happened. Sounds like when I'm shifting into gear I can hear like the gear bouncing or something like booowowoww(I know perfect interpretation)
and my shift knob won't stay tight...
Old 07-05-2016, 07:03 PM
Pop the shifter boot and make sure the two bolts that hold it down onto the torque tube are tight. Sounds like the whole thing is flopping around.
Old 07-05-2016, 07:15 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
a new shifter and linkage from only944.com has an amazing tightening effect on these transaxles. I think every 944 should have one.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 07-06-2016, 05:15 PM
