voo-doo's Avatar
Wheel question, cross post from RL
I am thinking switching from 15" wheels to 17", more choices for tires. I have an '83, early offset manual steering. What wheel options are there for early offset? I would prefer to not have to use spacers.
If I do go to a larger wheel are there changes that I would need to make. And how would it effect my car?
Old 05-23-2016, 10:16 AM
There are no factory 17" wheels with early 23.3mm offset. Aftermarket ones are available but they are heavy monsters. Nothing wrong with spacers if you get the non-adapter types and install longer studs. In fact, this is how the factory did it on the rear.
If you get heavier than-stock wheels & tyres, handling and ride-quality will suffer. Main benefit is improved cornering grip. On my '86 951 (early offset), I was able to use 17x10.5/11.5" wheels with 255/40-17 and 275/40-17 tyres by increasing offset by 1/2" to 35mm. Similar to what Porsche did in going from Turbo to TurboS.
Old 05-24-2016, 03:52 PM
Vehicle Enthusiast
You're gonna have to do some researching on custom wheels, as the backspacing will be different than stock. If you use a larger, wider wheel, chances are you'll need spacers. These links might help you.
944 Wheels FAQ
14.0 Performance Modifications
I personally love the cookie cutters, but couldnt stand the wheel gap in the rear. So, what I did was swap out my studs for longer ones, with the factory spacer and a second hubcentric spacer. Open ended lug nuts too.
Ive read not to go any larger than 17" wheels on a N/A 944 because it'll affect peformance.
84' 944- 115K M220 M456
Old 05-24-2016, 04:04 PM
Toofah King Bad
Rasta Monsta's Avatar
Search a u t o m o t i o n . c o m for "Euromeister." They may not be feather light, like the originals, but I've seen them on a few cars and they look fantastic. They do come in 17, and the price is right.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 05-25-2016, 07:55 AM
Nice look, are they available in a late offset?
Old 05-25-2016, 01:11 PM
944 Wheels FAQ
Note that the offset information in the 944FAQ is incorrect for some models. The '86 early-offset ones I think.
Old 05-25-2016, 01:54 PM
