Exclamation fuse I.D.
I was changing the lights on the fuel/temp gauge cluster on my '84 944 and when I hooked everything back up it didn't work, except of course for the lights. I connected everything back up the same way it came off. I'm thinking that I probably blew a fuse somewhere along the line. Underneath, where the fuse boxes are, there are 2 holders (to the best of my memory) -- an 8 holder and a 15 holder fuse box. The wiring diagrams are a bit confusing to read, so can someone tell me which fuse number (and on which box) is the fuel/temp gauge combo? Thanks.
Old 12-27-2002, 10:30 AM
SoCal Driver's Avatar
Doesn't really jump out at you when you look through the tech articals on Pelicans main parts board but here:
http://www.pelicanparts.com/944/944QA/944_early_fuse_panel.htm
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 12-27-2002, 11:15 AM
