This MUST be it (5k+ power loss/stutter)
It's probably what I suspected all along - a bad injector. It seems fine when I bench tested it and I'm on my 3rd set of new seals, but low and behold here it is bubbling away after I shut the car off . . .
https://youtu.be/2bRpGecZCWQ
The good news is I've resolved the oil leaks. Had them from the front and rear lower balance shaft and the oil cooler housing.
The forum member formerly known as jasonmx5
2014 Cayman S
Previous Porsches: '86 944 SPEC/Cup SP1 car, '83 944, '91 964 C4 Cabriolet, '77 911 Carrera 3.0 Coupe
Old 08-10-2016, 03:35 PM
More Boost!
Did you want to try the spare injectors off the fuel rail again to test this theory? Might just need a new injector?
Old 08-10-2016, 08:03 PM
Already ordered one. It has to be it. No way I could do those seals that many times and still have the same one leaking. I'm also going to pull the manifold. Is it true if they put the gaskets in the wrong way it can interfere with the injector? I suspect that may have happened with the previous owner. I think the number one port is opposite the other three if I remember correctly and I would not be surprised at all to find the gasket backwards.
2014 Cayman S
Old 08-10-2016, 08:15 PM
More Boost!
Correct. 1 is backwards, 2/3/4 normal. I wouldn't be surprised if this is the case.
This was on mine when doing the head over and replacing the intake, 3 installed backwards, 1 correct.
Old 08-10-2016, 09:55 PM
Better get that fixed or she'll burn down like that 924 in the other thread here....
Old 08-11-2016, 07:10 AM
Oh don't worry. I'm not starting it again until I get a new injector in there and check the gasket orientation. I've disconnected the battery as a precaution.
2014 Cayman S
Old 08-11-2016, 07:45 AM
Check this out.....
https://www.fiveomotorsport.com/product-search/?v=21290#srp
You will be in Love. I promise you.
Old 08-11-2016, 11:50 AM
Originally Posted by PHillary View Post
Check this out.....
Thanks. If the one I ordered works, I plan on doing them all. This will come in handy. Great pricing, too.
2014 Cayman S
Old 08-11-2016, 12:04 PM
Thaught you might like that, I got my whole set of 4 for less than $250.00
Old 08-11-2016, 12:08 PM
Not it. Time to pull the intake manifold and see if there's something amiss under there - if not, it may be time to cut my losses. Just getting frustrated. Sell it, the house and go buy a nice Cayman S...
2014 Cayman S
Old 08-15-2016, 07:48 PM
More Boost!
Bummer. I'd clean, and adjust TPS and ISV while intake is off, check and verify all rubber hoses are good under the intake, and triple check your vacuum lines too for breaks even though they are new.
Old 08-16-2016, 12:59 PM
I'd go with the newer style injectors, not the old-timey little potbelly stove ones. I am running them on one of my 968s and one of my 928S4s.
1987 928S4
1992 968 cabrio
2009 957 Cayenne GTS
Old 08-16-2016, 02:12 PM
... check and verify all rubber hoses are good under the intake...
I'd say this has potential to be the culprit. Remember that one hose we couldn't see from the ISV to the manifold?
2014 Cayman S
Old 08-17-2016, 07:15 AM
That big crack near the clamp is clear through. I suspect a couple others are as well. Other hoses look great of course, so I assumed (yes I know what happens when you assume) this one would be in similar shape. WRONG. Fingers crossed this is the solution.
2014 Cayman S
Old 08-17-2016, 07:18 AM
More Boost!
Yup that hose is bad, that is why I replaced all mine with the intake off, they might look good, but for the $40 for all 4 hoses, it is cheap insurance.
Both ISV hoses and AOS hoses should be replaced, and new clamps installed.
Mine looked just as bad when removed, they were hard as a rock and had major cracks on all of the hoses.
Old 08-17-2016, 08:02 AM
Well, I ordered new hoses for under there. Whether that fixes the problem or not, I may still sell the house and buy a Cayman S
2014 Cayman S
Old 08-17-2016, 08:54 AM
More Boost!
Sounds good, keep us updated. Hopefully this is your fix, if not, stop by with the Cayman S w/ sharkwerks package and I'll sell both the 944 and the 951.
Old 08-18-2016, 07:24 AM
. . . if not, stop by with the Cayman S w/ sharkwerks package . . .
. . . and beer. You forgot beer! Last hose should be in today. I'll throw it all back together tonight and let you know.
2014 Cayman S
Old 08-22-2016, 07:14 AM
All new hoses and still the problem exists. I'm done. If anyone in the New England area is interested, $1700 and it's yours. 1986 944 Base. Copenhagen Blue. Stripped interior, all new oil seals, hoses, plugs, wires, rotor, cap, lots more. 6 point bolt in roll cage, 2 Corbeau GT seats. Basically a package racecar deal.
Once this and the house are sold, I'll be in the market for a 2009+ Cayman S or possibly 993 if I can find a decent one in my budget.
2014 Cayman S
Old 08-23-2016, 01:07 PM
More Boost!
Wow, that stinks. I cannot think of anything else that would cause this. Bring the beer and the new-to-you cayman S/993 when you can.
Old 08-23-2016, 04:40 PM
