Lifters - question to replace?
When hydraulic lifters lose their "spring" does this mean they need to be replaced?
1988 Porsche 924S - On the road again after 3+ years.
Dodge GC ES 278,xxx and counting.
Old 08-22-2016, 09:10 AM
rufrob's Avatar
Not necessarily. From my experience sludge can build up if oil changes lapse. If several are noisy then change oil more frequently. If it's just 1 with high mileage then it could be bad. Highly unlikely.
Never give up
Old 08-22-2016, 12:52 PM
Banned
probably.
but if your getting a sound like lifter noises in a 944, the first place i would look is the cheesehead on the front of the cam sprocket. i know of 3 944s that all the lifters were replaced, and were slighly soft, but the noise didn't go away, and it ended up being the cheesehead on the front of the cam.
Old 08-22-2016, 01:43 PM
Originally Posted by cockerpunk View Post
probably.
Lifters are out of the head and soaking in jars of new motor oil now. They were removed after the head gasket blew on PO. 2 of the lifters have no spring action.
I have since been advised by a local 924 supplier in south Florida that they should be replaced. I will likely get 2 refurbished ones.
Thanks.
Old 08-24-2016, 01:22 PM
I see no need to replace lifters, "springy" or not...there is nothing inside them to "go wrong".
They probably just need to be cleaned thoroughly (maybe ultrasonically?) and fed fresh clean oil again...
Old 08-24-2016, 01:37 PM
rufrob's Avatar
I have heard of the spring inside the lifter can crack thus fail. But usually the tiny hole gets plugged which causes the lifter to fail.
Never give up
Old 08-24-2016, 02:02 PM
Banned
lifters are also like mega cheap. i think when i did mine, i paid like 8 bucks a lifter?
Old 08-24-2016, 02:11 PM
Must not have been new ones...they are over $200/each nowawadays
Old 08-24-2016, 04:15 PM
If you buy them in the $160 Porsche box, they are. OEM INA (in the INA box) lifters for those engines are about $40.
87 944N/A since 1992
87 944S - Near Future Engine Project Car
88 944S - Current Project
84 928S - Restoration Project
Old 08-24-2016, 04:23 PM
mhariush's Avatar
I know for the S you can buy INA VW lifters (from the 16V Golf), they probably have VW lifters for the NA's too, if the S doesn't work...
I have some used lifters if anyone is in need. $5 ea and shipping.
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero
instagram @mhariush http://stores.ebay.com/Techniker-Parts/
Old 08-24-2016, 10:58 PM
Do they work also for 951? Can you please share some part codes?
Old 08-25-2016, 12:20 PM
Same part for the 951 as the 924S and 944N/A. Porsche part number is 92810531108 for all of them.
INA part number is 122-08024434 at Parts-Geek (remove the dash in the name for the website). $39
Old 08-25-2016, 12:40 PM
Thanks a lot!
Edit: I checked that website and it seems that they have only S model lifters
Old 08-25-2016, 01:12 PM
Well damn.. I didnt' notice that. Still there's got to be some available for less than gold prices..
Old 08-25-2016, 03:02 PM
