-   -   Lifters - question to replace? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/926412-lifters-question-replace.html)
Austin87 08-22-2016 09:10 AM
When hydraulic lifters lose their "spring" does this mean they need to be replaced?
rufrob 08-22-2016 12:52 PM
Not necessarily. From my experience sludge can build up if oil changes lapse. If several are noisy then change oil more frequently. If it's just 1 with high mileage then it could be bad. Highly unlikely.
cockerpunk 08-22-2016 01:43 PM
probably.
but if your getting a sound like lifter noises in a 944, the first place i would look is the cheesehead on the front of the cam sprocket. i know of 3 944s that all the lifters were replaced, and were slighly soft, but the noise didn't go away, and it ended up being the cheesehead on the front of the cam.
Austin87 08-24-2016 01:22 PM
Originally Posted by cockerpunk (Post 9250812)
probably.
Lifters are out of the head and soaking in jars of new motor oil now. They were removed after the head gasket blew on PO. 2 of the lifters have no spring action.
I have since been advised by a local 924 supplier in south Florida that they should be replaced. I will likely get 2 refurbished ones.
Thanks.
v2rocket_aka944 08-24-2016 01:37 PM
I see no need to replace lifters, "springy" or not...there is nothing inside them to "go wrong".
They probably just need to be cleaned thoroughly (maybe ultrasonically?) and fed fresh clean oil again...
rufrob 08-24-2016 02:02 PM
I have heard of the spring inside the lifter can crack thus fail. But usually the tiny hole gets plugged which causes the lifter to fail.
cockerpunk 08-24-2016 02:11 PM
lifters are also like mega cheap. i think when i did mine, i paid like 8 bucks a lifter?
v2rocket_aka944 08-24-2016 04:15 PM
Must not have been new ones...they are over $200/each nowawadays :)
dgcantrell 08-24-2016 04:23 PM
If you buy them in the $160 Porsche box, they are. OEM INA (in the INA box) lifters for those engines are about $40.
mhariush 08-24-2016 10:58 PM
I know for the S you can buy INA VW lifters (from the 16V Golf), they probably have VW lifters for the NA's too, if the S doesn't work...
I have some used lifters if anyone is in need. $5 ea and shipping.
smudo 08-25-2016 12:20 PM
Do they work also for 951? Can you please share some part codes?
dgcantrell 08-25-2016 12:40 PM
Same part for the 951 as the 924S and 944N/A. Porsche part number is 92810531108 for all of them.
INA part number is 122-08024434 at Parts-Geek (remove the dash in the name for the website). $39
smudo 08-25-2016 01:12 PM
Thanks a lot!
Edit: I checked that website and it seems that they have only S model lifters :(
dgcantrell 08-25-2016 03:02 PM
Well damn.. I didnt' notice that. Still there's got to be some available for less than gold prices..
