Wobbling problem
Last few i notice an increase of wobbling of the car at or above 70mhh and specially when i'm accelerating.
Any suggestions or ideas what may cause that? Thank you guys |
Cheapest solution would be to have your tires rebalanced.
Incidentally how old are the tires?
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
common problem see list
1> also known as "944 shimmy", supposed Audi/running gear orgins 2> make sure you get a proper 4 wheel alignment, OPC takes about 2-4 hours 3> wheel balancing done properly as well 4> make sure wheels/tyres/nuts are mounted properly (as in your driving manual) a) one of the 5 wheel studs as a flec of paint on it, the wheel should be moun5ted as follows, the tyre /valve closest to the hole should go on this stud b)the locking wheel nut goes on this stud only c) dont use any other lockers except the OEM part HTH Adrian
----------------------------------------------------------- The fear of God is the begining of wisdom <>< NotJustPorsche Subscribe: notjustporsche-subscribe@yahoogroups.com |
