Reverse light switch - 968
My backup lights are not working, where is the switch under the car?
The reverse light switch is on the transmission. Should be one of two electrical connections on it. The other is the speedometer.
Should be top rear of the trans.
passanger side, top of trans.
The reverse lights on my 944 don't illuminate unless I apply extra pressure to the shifter. If the shifter is in Reverse, the lights are off unless I push back on the shifter a little bit. I'm guessing that this extra pressure is needed to engage the switch located on the transmission.
Is there any adjustment possible here or is the solution just a new switch? THanks! |
Same for an SC?
Have an 81 SC and lights don’t come on when car in reverse. Same type of switch I assume? Where is it located? Anyone know? Thanks in advance.
I happen to have an SC. On its 915 transaxle (also used on Carrera 84-85), the reverse light switch is mounted on the nose/very front of the unit, next to the shift selector shaft (where the shift rod connects). John
There you are....Location of reverse ligths switch on your 968 pull the rubber boot:D |
