Reverse light switch - 968
My backup lights are not working, where is the switch under the car?
Old 08-29-2016, 11:23 AM
The reverse light switch is on the transmission. Should be one of two electrical connections on it. The other is the speedometer.
87 944N/A since 1992
87 944S - Near Future Engine Project Car
88 944S - Current Project
84 928S - Restoration Project
Old 08-29-2016, 01:10 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Should be top rear of the trans.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 08-30-2016, 11:26 AM
Alexb944's Avatar
passanger side, top of trans.
Old 08-31-2016, 04:41 AM
The reverse lights on my 944 don't illuminate unless I apply extra pressure to the shifter. If the shifter is in Reverse, the lights are off unless I push back on the shifter a little bit. I'm guessing that this extra pressure is needed to engage the switch located on the transmission.
Is there any adjustment possible here or is the solution just a new switch? THanks!
1984 944 Zermatt Silver
1987 951 Flamingo Metallic
Old 04-22-2020, 12:19 PM
Same for an SC?
Have an 81 SC and lights don’t come on when car in reverse. Same type of switch I assume? Where is it located? Anyone know? Thanks in advance.
Old 10-10-2020, 12:17 PM
You might want to ask this question on a 911 forum, not a 844 forum.
Good luck, George Beuselinck
Old 10-10-2020, 01:38 PM
I happen to have an SC. On its 915 transaxle (also used on Carrera 84-85), the reverse light switch is mounted on the nose/very front of the unit, next to the shift selector shaft (where the shift rod connects). John
Old 10-10-2020, 02:29 PM
Ernie944's Avatar
There you are....Location of reverse ligths switch on your 968 pull the rubber boot
Caraquet,N.B. Canada.
Old 10-11-2020, 03:12 PM
