Eduardo Castrejón Elbjorn's Avatar
Send a message via ICQ to Eduardo Castrejón Elbjorn
Question Temperature Sensor
1984 944 auto
I supose that my Temperature Sensor is ok but I bought a new one.
In the bosch fuel injection book says that is one of the most important, then after 19 years, will be a good idea to change.
Any type to change it ?
Loctite ?.etc
let me know
regards
Old 01-06-2003, 09:39 AM
SoCal Driver's Avatar
Engine to DME temp sensor uses a gasket as it goes into the water jacket of the engine block. Has straight cut threads not tapered as in water pipes.
The single pole gauge sensor that's just behind the DME temp sensor is a tapered pipe thread. But mine goes into a blind hole -- not drilled through to the water jacket.
I would condsider using teflon tape on both. Or a teflon paste.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-06-2003, 10:24 AM
Socal:
Thanks for your answer
Is the dme.
I already installed with a little of loctite (blue)(removable)
Regards
Eduardo
Old 01-06-2003, 10:48 AM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
Good call, Ed.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 01-06-2003, 12:47 PM
