944S Boyeee's Avatar
Send a message via ICQ to 944S Boyeee
Inside Door Lock feature...is it working?
Was just curious if when you push the lock button (on the centre console - where the sunroof button is) are both doors supposed to lock?
Whenever I push that button, only the passenger side locks. Is this correct?
944S Boyeee
1989 928S4 Canadian Edition
75,000 klms
Old 01-10-2003, 06:17 AM
No they are suppose to both lock...i have the same problem! There is a little white plastic arm that goes from the power lock mechanism to lock mechanism itself that latches onto the car to shut the door. Your driver side probably just popped off, if you take your door panel apart and look in the top left of the driver door, look for a little white arm that is not connected and click it back on the metal ball. My passenger one actually broke, i know its a tiny little piece but i need it, if someone would take the hassle to sell me i'll give you like 5 bucks for it, its just a little plastic piece, thanks
John
Old 01-10-2003, 06:46 AM
Thanks Roastin - I'll check that out.
I figured something was loose or disconnected.....I could hear something in the drivers door trying to catch something.
944S Boyeee
75,000 klms
Old 01-10-2003, 06:56 AM
