Ornery Bastard
Wiper motor help needed, wipers not parking.
The wipers on my 1987 924S stoped parking properly. How do I adjust the mechanism so that the wipers park in the proper place? They currently park at about three quarters of the way from full "up". The motor was replaced about a year ago according to the maintenance records I have, and even when I got the car the wipers would only park in intermittant (which they have now stopped doing too.
Is it even possible to adjust this, or is it a precursor to a full failure of the wiper motor? Aaron
--------- Silver 1998 Volvo S70 T5 <- Daily (Anja) Guards Red 1986 951 <- Seattle car (Gretchen) White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei) |
Same thing happened to my 81 924 na. Remove the switch and clean the ground. I had to replace the switch though.
Roger Hall 81 924 N/A Some people are like Slinkies. Not really good for anything, but you still can't help but smile when you see one tumble down the stairs. |
Ornery Bastard
Aaron
They redesigned them with the 85.5 I am not sure where yours is. If I remove my streeing wheel mine a contact at the bottom.
If the intermittent and park don't work you need the intermittent wiper relay. Note that this part is superceeded to a 993 part number and you have to cut one of the terminals off to make it fit the socket.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
