2001 Boxster s O2 Sensor Question
I have an 01 model with 36K miles. The CEL came on recently and the codes read P1126, and P1131. My question, is there a way to tell which of the sensors need replacement either pre or post cat.
Old 12-30-2016, 03:49 PM
flash968's Avatar
try the 986 (boxster) area.
Old 12-31-2016, 07:16 AM
p1126 on boxster means the upstream (pre-cat) O2 sensor on cyl4-6 side (driver side) of engine is out of range.
post-cat sensor problem would be a p0420 or p0430
with such low miles i don't think (though certainly not impossible) that the O2 sensor is aleady bad unless you had another problem.
clear the code with a code reader (or battery disconnect to reset ECU) and drive around for a while and see if it comes back.
Old 12-31-2016, 07:53 AM
