Send a message via Yahoo to asudds
Short Shift Kits Questions
Has anyone on the list purchased a short shift kit for their car?
Who sells SS for the 944 Series
What are some of the best SS kits available for our cars.
I need to replace my shift knob and shifter bushings, thought I
might as
well upgrade to a SS kit at that time as well.
Aaron Sudds
1987 924S, 944S, 911 cab
Old 01-15-2003, 05:51 PM
sasquatch's Avatar
I built a copy of the Performance Products short shift kit when I was installing my S2 gearbox in the 87. I used all stainless heim joints and the proper shouldered bolts throuout. My throw is about 40% shorter and I would never own another 944 without this mod.
I feel that the PP kit would be close to as good as mine except for the fact that I even replaced my stabilizer rod (goes accross top of transmission from shift linkage) with an adjustable rod and heim joints.
There is zero play in the mechanism. My shifter feels like it is gated.
Pelican may have these kits as well.
Sasquatch
1987 Porsche 944
1974 Porsche 914
"Don't retreat, reload." Sarah Palin
Old 01-15-2003, 07:47 PM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
please explain why this is such an important improvement. i have trouble justifying the price, and maybe if you explained it, i might understand better.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 01-15-2003, 07:56 PM
Send a message via AIM to XJOSHX Send a message via Yahoo to XJOSHX
I know that speed force racing sells a short shifter for 100 bucks. I don't know anyone that has tried it but I have heard good reviews on every other product they make. I am not sure if their shifter is shorting in apearance or true has a shorter throw. check it out. www.speedforceracing.com
1983 944 - Project Time!
1986 944T (Stolen)
1987 944 N/A (Sold)
1984 944 N/A (Sold)
1986 944 N/A (Sold)
Old 01-15-2003, 10:36 PM
1.2gees's Avatar
Send a message via AIM to 1.2gees
Can we have some pictures of your modifications?
Ahmet
Cheers!
Old 01-16-2003, 03:18 AM
sasquatch's Avatar
Now that I have a digital camera, I'll have to get under there and see if I can get a couple of photos.
If the stock system is in good shape, all that you will gain is about a 40% shorter throw between gears.
With the way I built mine, I replaced all of the rubber gromets with SS heim joints so there is zero play. The shifter is extreemly precise. The feel of it snicking into the gears is much enhanced. I did not notice any real vibration increase like I thought though.
If I had to purchase this product retail for the price that they are charging, I probably would pass. There are much better places to drop a bill. But, since I have a full machine shop at my disposal...I built it for around $30 in parts. The joints and shouldered bolts were all sourced from McMaster Carr.
My next project is to do the same to my 914.....
Sasquatch
1987 Porsche 944
1974 Porsche 914
Old 01-16-2003, 06:32 AM
Writer/Teacher
CJFusco's Avatar
"please explain why this is such an important improvement. i have trouble justifying the price, and maybe if you explained it, i might understand better."
anyone?
Old 01-16-2003, 09:46 AM
sasquatch's Avatar
CJFusco, I explained it in my previous post, here let me say it plainly.
-> 40% shorter throws
-> Much more precise feel
-> Cool factor
Sasquatch
1987 Porsche 944
1974 Porsche 914
Old 01-16-2003, 09:51 AM
Writer/Teacher
CJFusco's Avatar
Well the throws in a 944 aren't exactly long or imprecise to begin with, so I honestly don't really see the point. Perhaps if I drove a car outfitted with this? Is it really that noticable? Does it make a huge difference in drivability and/or fun?
Old 01-16-2003, 10:07 AM
least common denominator
scottmandue's Avatar
Porsche Crest
sasquatch,
Very interesting, a digital picture would help for those of us who are "mechanically challenged".
I will dig up our McMaster Carr and look up heim joints and shoulder bolts in an attempt to edumakate mieselph!
Thanks,
Scotticus Maximus
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 01-16-2003, 10:50 AM
Hey Sasquatch, would you be interested in reproducing your kit and reselling it at a price you thought was fair? Either that, or possibly explain, because I have access to "friend's" in a machine shop, and with a slight plan, I could have some made possibly. If it's anything like the shifters on the FWD cars I've owned, you just add longer material to the bottom of the rod, is this the same setup? Also, where did you find the bushings?
Yes the motor is in the front....
Old 01-16-2003, 10:57 AM
SoCal Driver's Avatar
Technically what a short shift unit does is to replace the back end of the shift linkage with shorter travel (radius) arms. There is a side to side arm that selects the gears and the fore and aft arm that engages the selected gear. Here's a picture of the stock set up. What Jay did was to replace the rubber bushed shoulder bolts on the top arm with steel ball joints.
The short shifter unit replaces entire end of the linkage (that's the section the engagement arm bolts to), the cross over link and the lower cast arm (the engagement arm).
I do think that the shift lever and it's support socket could be modified and provide close to the same utility with out having to crawl under the car.
I do like the idea of replacing the cross over arm with stainless ball joints.
PS: That's an open end wrench you see to the left on the hex head bolt.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-16-2003, 11:24 AM
sasquatch's Avatar
I thought about reproducing the kit, but I would be up where the other kits are in price, so I would not have any edge. I will take some photos when I get home tonight and post them tomorrow. I ended up replacing everything that is in the photo above. There was considerable trial and error as well. My kit is not pretty, but extreemly functional.
Sasquatch
1987 Porsche 944
1974 Porsche 914
Old 01-16-2003, 11:40 AM
Can you buy the ball joints anywhere, and would the likelyhood of them popping off be a concern? The ball joint method is what I've seen alot of H20 VW people do, I just haven't really thought about doing it myself till now.
Old 01-16-2003, 12:29 PM
sasquatch's Avatar
I am using actual heim joints and shoulderd bolts. These will not pop off since they are bolted through. I sourced all of my parts throught McMaster Carr. They are all metric and stainless steel.
Sasquatch
1987 Porsche 944
1974 Porsche 914
Old 01-16-2003, 12:37 PM
One needs to have an established account at McMasters. Unless they have changed their policy. Getting an account is like pulling tortoise teeth. One of my most prized books is a McMasters catalog.
Depending on where you live there might be an industrial hardware supply that you can order small quantities from. Also try to find a local supplier called Kaman Bearings. Or anything non musical in the industrial section of the business to business yellow pages.
Old 01-16-2003, 12:43 PM
I'm going to check with McMaster, I got the impression if you can walk into one of their stores (we have them here is S. Cal) any dork could buy stuff. I hope so because my continually put off "garage clean up project" involves purchasing a large number of plastic bins to organize a small mountain of nuts/bolts/screws/nails/electrical/construction/plumbing/painting/audio equipment/automotive/motorcycle stuff from a collection of cardboard boxes/paper cups/coffee cans. The bins I saw at Homo depo could be torn apart by a six month old baby.
Gary Fisher 29er
1995 Miata Sold
1984 944 Sold
Old 01-16-2003, 01:01 PM
I've ordered stuff from them over the phone with a credit card. They also have a web page at:
http://www.mcmaster.com/
as far as a catalog goes, while it is tough to get a printed version, they will give out a cd version without much of a fuss.
Rob
Old 01-16-2003, 05:32 PM
I have pretty well the same mods as Sasquach. I have the GPR short shift kit on the tranny, which is a copy of the Autothority, the DST link bar that replaces the factory sheet metal unit, and lastly the billet shifter by David Harrington. The shifting is quite close even when set wider/longer positions, and a bit tight. And the billet shifter sometimes rattles when cruising.
Old 01-17-2003, 03:01 PM
