Zombie
Fuel lines labeled to show age?
Just wondering...if there are any symbols/numbers/dates, etc. on engine-compartment fuel lines that will tell me their age?
No. They are probably original, which means they are pushing 30+ years.
Good luck, George Beuselinck |
does it have a Porsche part number printed on the hose?
if so...replace. |
does it not have a Porsche part number printed on the hose?
if so...replace. FTFY
Yep, lots cheaper than replacing everything under the hood, including the fuel lines.
If over 30 years old change them or you'll regret it. Seen too many pictures of ALFA's burn't up because of this lack of maintenance. Can't blame it on ethanol, that's "BS" Bet your brake hoses were changed by now, why neglect the gas lines, it's an explosive!
You'll take one out and see if you press the end how cracked they are and how dangerous it is not to replace them.
AlfasRule! 72 Montreal (Da Pumpkin) 75 Alfetta Sedan, 75 Alfetta Coupe Race Car 82 Spider, 84 GTV-6. 84 GTV-6 Verde (GiGi) 87 Milano ( Da Winta Beata) |
![]() This is NOT what you want to happen............ ![]() I have repair hoses that do not require replacing the complete hose assys...... ![]() They are E-85 rated and considered factory level by most who know my work. Len at Autosportengineering dot com
+1 for Len's solution!
+2
There is usually at least one Melba toast post every year come spring. |
How much fer dem purdy hoses ye got there?
87 944N/A since 1992 87 944S - Near Future Engine Project Car 88 944S - Current Project 84 928S - Restoration Project |
Toofah King Bad
The Bay of Renn also purvey a fine solution.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
![]() These are shown in post #8 above and are for the front of a 924S and 944/1. Hard to show once installed but this is what I have......... ![]() ![]() The photos show the replacement E-85 rated hoses installed with 1) Foam Insulation and 2) Aftermarket Insulation the customer provided. As you can see here..... ![]() the area behind the Brake Booster is tight and not accessible for crimping new hose unless the Booster is removed. To save all this extra work, I have been able to make up longer hoses that connect below the Booster in the area under the pedals & floor boards...... ![]() The hardlines are cut and connections are made with Metric Flare fittings and as factory in design & construction. Optionally, I have Metric compression fittings if a flare tool is not available. Hope this helps. Len
