Exclamation Jacobs Ignition Coil - Advice Please
Just got a Jacobs Energy/Ultra coil and figured it would be as simple as swapping out the old with the new. On the bottom of the coil there is a sticker talking about adding an External Ballast Resistor for applications like Bosch and Lucas. How do I identify if I have/need an External Ballast and do you have any recommendations??
Jacobs also claims I can run with a bigger Sparkplug Gap . . . what would the benefits be to running a bigger gap?
Many thanks in advance for any information you can provide.
Best Regards,
Chuck
Old 01-23-2003, 09:52 PM
justin's Avatar
What year is this car? What voltage is the coil rated at?
Texas hosts the 928 Owner’s Club OCIC in 2009
www.928ocicdfw09.com
1980 928 5 speed and a few mods..........
928 OC member
PCA member
Old 01-23-2003, 10:19 PM
not sure. . .
No information on the packaging and nothing on the coil. Performance Products marketing mumbo jumbo states "This patented design increases or decreases spark energy based on the demands of the engine. The coil produces a consistent 28,000 volts, regardless of plug condition, heat or engine rpm. It features ultra-rugged construction and heat conductivity"
Old 01-23-2003, 10:30 PM
whoops. . . it's a 1987 924S
sorry .. .forgot the model year . . .1987
Old 01-23-2003, 10:31 PM
justin's Avatar
Ok, I don't think you need a resistor.BUT you might want to e-mail Jacobs to be sure,I have a Accel coil on my 83' with no problems.
928 OC member
PCA member
Old 01-23-2003, 10:37 PM
thanks . . .
I'll confirm with them tomorrow. Did you notice any difference going with a better coil?
Any suggestions if I should increase the gap in my sparkplugs? I'm curious what the perf benefits would be. Jacobs indicates I can increase the gap by .010 over standard
Many thanks again for your advice!
Chuck
Old 01-23-2003, 10:40 PM
1.2gees's Avatar
Send a message via AIM to 1.2gees
I would increase the gap slightly but no big deal. I used this coild (along with other ignition stuff) on my 84 for a while without any problems but I'd like to see what you'll hear before I install it on my turbo so please let us know what you find out from Jacobs.
Ahmet
Cheers!
Old 01-24-2003, 01:18 AM
AFJuvat's Avatar
Used them both (jacobs coil and wires) with good success.
They have you open the gap because the coil is "hotter" than stock - allowing a more powerful spark - opening up the gap takes advantage of this.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 01-24-2003, 03:25 AM
I bought their entire system a couple of years ago. Darn thing did not work properly after about 5 minutes. I eventually returned it for a full refund. I was greatly disappointed. But for those 5 minutes, the engine was silky smooth. I imagine I got a defective one.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 01-24-2003, 04:20 AM
least common denominator
scottmandue's Avatar
Porsche Crest
Okay guys I bought one of these a few years back but the ballast resister note scared me off from installing it, I was a-feared that it might melt down parts of my electrical system thus being more trouble than it was worth.
IIRC it was a chrome and blue round coil.
SO...
Chuck, AFJuvat, Ahmet:
Is this the same coil you are talking about?
Can I install it without the resistor?
The coil I have is a slightly smaller diameter how did you fit it?(I have vowed not to use duct tape on my Porsche)
TIA
Scott
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 01-24-2003, 10:15 AM
That's what I have . . . its' the "ultra". I'm still trying to track down if I can install without a resistor. As for fit, I purchased the Jacobs mounting bracket that goes along with it (extra $5 from Performance Products.
Old 01-24-2003, 10:37 AM
Called Perf Products . . . and didn't even get to finish my sentence before he was giving the answer. Guess they get a lot of calls about it!
Anywhoo, said the ballast is for cars with points. 87 didn't have points so don't need it. If you've got points, don't use. I assume it will fry them.
Cheers!
Old 01-24-2003, 10:52 AM
AFJuvat's Avatar
No 944 has points.
Old 01-24-2003, 10:57 AM
Thumbs up
Way cool guys!
Now I have dig through the garbage dump... I mean my garage to find the silly thing.
Ah yet another project!
Gary Fisher 29er
1995 Miata Sold
1984 944 Sold
Old 01-24-2003, 11:09 AM
SoCal Driver's Avatar
Originally posted by AFJuvat
No 944 has points.
Electronic points!
That is the transistors required to ground the "other" side of the coil. Might check this out with those that tear into the DME brains to see if it can handle the switching loads.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-24-2003, 11:49 AM
Re: Ballast Resisters
They were used on points to reduce the voltage going to the point contacts once the engine warmed up. This was done to extend the life of the points. The ballast resistor provided 12 volts to start a cold engine, and dropped to six volts as the resistor heated up. Triumphs used to use them, but discontinued in the '70s as point contact material improved. Like you guys have said: no points = no ballast resistor.
I love a good working electronic ignition. But I can't do a thing to it if it doesn't work. At least I was able to reset points.
Stay Posted - more to come.
Old 01-24-2003, 11:51 AM
Dewl meters!
Had a Snap-On until my garage was burgled 16 year ago. Then no reason to replace it because of the electronics in the newer cars.
Old 01-24-2003, 12:01 PM
Ah, Yes. The lovely dwell meter. Took me the longest time to figure out what that thing actually did. I still have one in one of my tool chests. Haven't used it since the late '70's. Wonder if it'll still work. In the 60's we used to set VW points with a match book cover. It was close enough to allow the engine to run. That's the main advantage of a de-tuned engine. It'll almost always run if you're even close to the right setting.
Old 01-24-2003, 12:17 PM
Thanks to all for your advice/input. Coil is installed and . . . no noticable difference but time will tell. Helpful advice for you though, the coil is smaller than the bracket so you will need some type of shim material (take sheet metal and cut a strip).
The Jacobs add on bracket does not seem to work on the 924S because the mounts are different. I ordered the bracket prior to learning this, figured it would sit on my shelf and rot so used it for my shim. Just cut off the mounting strips - worked like a charm.
Cheers!
Old 01-25-2003, 01:52 PM
Well thanks, just saved me $5 to buy the bracket that will not fit.
I bought the coil with wire/cap/rotor/plug and gave her a tune up when I first bought the car. Car had a slight stumble between 3K and 4K rpm. After diveing her for a while many small problems like this started to disapear. Leads me to believe the car sat idle for a long while before I bought it. Proof to me that it is not a good idea to let these cars sit for long periods of time.
Gary Fisher 29er
1995 Miata Sold
1984 944 Sold
Old 01-25-2003, 02:52 PM
