Track Wheel Question
I have a 88 944 with 15x7 phone dials. Looking to upgrade to the 16x8 phone dials off of the Turbo models. I am thinking square would be a better setup versus staggered so that I can rotate tires.
Any input or alternatives that might be a better option? |
yes, a square setup is ok.
four 8's is ok... Four 9" club sport wheels would be even better if you have front coil overs with smaller diameter springs than stock. |
Going faster all the time
First Turbo Phones (86) are the wrong offset just FYI.
Later Turbo Phones (87+) will be what you need. They will be heavier than your 15s... and heavier is almost always worse.
Now: 1997 German-built Boxster - Black Then: (2) 1973 914 2.0 Marathon Blue | 1986 944T Alpine White | 2004 40th AE 911(996) #898 | 1987 944 Guards Red | 1976 914 2.0 Summer Yellow | 1974 914 2.0 Light Ivory | 1986 944T Black | 2006 Cayenne Turbo S - Titanium Gray |
Toofah King Bad
15 are better for the track, and even though cast, phonies are light relative to other late offset factory wheels. They are also a dime a dozen, and easy to put tasty race rubber on.
Watch Craigslist, and start collecting 15x7 phonies.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
Other than price do you think that the 15x7 are a better option? If so why. |
Toofah King Bad
How wide do you want them, and why? 225/50 is the spec tire for more than one 944 racing series.
Reasons against: 15 are lighter and easier to buy race tires for; smaller diameter improves acceleration. |
225 seems like a lot for a 7" wide wheel but it looks like a lot of people run them. That is the size I was thinking for a 8" wheel. Maybe I will look into some 16x7. It doesn't seem like there are any street/track options for the 225/50/15.
There's a few: Tire Rack - 225/50-15 tires
The Toyo Proxes RA-1, R888 and R888R will give you a good balance of combined street/track usage. The shorter tyre will give you a little lowering and faster acceleration due to lower effective gear-ratio. Last edited by DannoXYZ; 12-19-2016 at 09:59 AM.. |
![]() Generally I would not go to smaller outer diameter tire as it will have less traction due to smaller contact patch area, might heat up quicker due to that reason and will have higher rolling resistance (if the same width), but as suggested above, you might benefit from faster acceleration on track with long straights and slow corners. My 951 has 260 WHP, thus it is not a "momentums car'' compared to NA 944. 15 inch wheels with 225/50 Toyo R888 tire might be a fast set-up on track but I would not drive those tires on street for various reasons (comfort and cost mainly). But you can also go with 225/50 16 or 225/45 16 if you want smaller outer diameter. Or you could also go to 245/45 16 (you can use them with either 8’’ or 9’’ wide wheels), but not recommended with OEM suspension settings (it will be too soft for such a wide and sticky tires – you will get a lot of body roll). Last edited by smudo; 12-27-2016 at 09:04 AM.. Reason: misspelling |
Toofah King Bad
Exsqueeze me?
"less transaction" means it can't bargain with the pavement as well as a bigger, tougher tire.
Contact patch has nothing to do with the size ("width") of your wheels or tires neither does traction.
Mike A 9TECHNIK | TRANSAXLE ÄRA 1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab. Last edited by 9FF; 12-28-2016 at 06:29 PM.. Reason: Edited for clarity as we are talking about tire width |
Same tyre/compound, then yes, contact patch size will have an effect on your mechanical grip.
Patrick Youtube 333pg333 86 modified 951 |
Coeffient of friction x weight is the equation, there is no length, width or area of contact patch in the calculation. Now if you increase contact patch due to weight then yes, but not size of tire.
Mike A 9TECHNIK | TRANSAXLE ÄRA 1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab. |
Toofah King Bad
No more correct than any of that post!
This is very interesting topic. There are many factors that impact the cornering speed. We are talking about track tires which while driving on the track are close to their limits as well I assume that the car will have proper suspension alignment and tire pressure for its size. There is a lot of information available on the internet if you are interested in this topic. However, generally in case of 944, e.g. 205 mm wide tire will result in slower lap time than 225 mm wide tire.
I found one interesting discussion and copied reference and some extracts from that discussion below. Reference https://www.physicsforums.com/threads/how-does-traction-compare-to-the-width-of-a-tire.587766/ I've been involved in racing for over thirty years and have performed quite a bit of tire testing on cars ranging from street to NASCAR and Formula cars; it's important to know how the various tire specs affect the performance of the tire and of the overall vehicle package. Know how tires work and you'll have a big advantage over your competitors while saving time and money by not making random changes and hoping they work. ...... The load on the tire affects the traction; the width does also but for a different reason. As a tire reaches its traction limit during cornering, the rearmost part of the tire starts slipping first. This starts at roughly the same distance from the leading edge of the contact patch. This means that a wide but short patch shape will have less of the total area slipping at a specific slip angle (directly related to the force on the tire) than a long narrow contact patch. As a result, a wide tire generates more grip than a narrow tire at the same unit loading. ..... There aren't any charts for this because most people use the widest tire allowed by the rules but rough calculations show an increase in grip of about 3.5% when going from an 8" to 10" tire. |
Toofah King Bad
Needless to say, tire width and wheel diameter are two totally different things.
This explains it well, from Road & Track:
When you install wider tires without changing anything else, the size of the tire's contact patch (i.e., the rubber touching asphalt) stays relatively constant. That size is based on a tire's overall diameter, inflation pressure, and the weight acting on it. Installing fatter tires widens the patch, but it also shortens it front-to-back. Because of this, cornering gains can be offset by diminished straight-line traction, including braking and hydroplaning resistance. The increased mass and friction can also translate to slower lap times and a drop in fuel economy. If you want to improve cornering grip, you're better off switching to a higher-performance tire of the same size. Buy right, and you'll get a stiffer sidewall for crisper turn-in and steering feel, as well as a stickier rubber compound and a tread pattern focused on dry grip. Width won't do it. Merely increasing the width of a tire doesn't increase the area touching the pavement. It just makes it a wider, shorter patch. A bigger donut. If other vehicular factors remain constant, increasing a tire's overall circumference is the only way to enlarge the contact patch.
Mike A 9TECHNIK | TRANSAXLE ÄRA 1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab. Last edited by 9FF; 12-28-2016 at 05:29 PM.. |
![]() There are a lot of factors that impact the cornering speed of the car and the tire width and outer tire diameter are just two of them. Next year I will be able to compare my lap times and overall feeling of my 951s handling on a track that I now well (using 255/40 17 tires) with other factors being quite similar to last couple of years when I used 225/50 16 tires. |
